Integration Manager - Call the Microsoft.Dynamics.GP.IntegrationManager.ini from a batch?
  • 1.  Integration Manager - Call the Microsoft.Dynamics.GP.IntegrationManager.ini from a batch?
    Posted Oct 07, 2022 04:36 PM
    I will be moving all GP and Integration Manager users to a pair of Terminal Servers soon as part of an upgrade to GP 2018 R2.
    I would like to build a batch that opens IM with a User's IMD file and their specific INI, with a variable path.
    IM.bat
    @echo off
    T:
    CD\Integrations\%USERNAME%
    start "" "C:\Program Files (x86)\Microsoft Dynamics\Integration Manager 12\Microsoft.Dynamics.GP.IntegrationManager.exe" Blank2.imd Microsoft.Dynamics.GP.IntegrationManager.ini
    The first part works, I can use the %USERNAME% variable to open up an IMD file.
    INI Path: C:\PROGRAM FILES (X86)\MICROSOFT DYNAMICS\INTEGRATION MANAGER 12\MICROSOFT.DYNAMICS.GP.INTEGRATIONMANAGER.INI
    Adding the "ini" to the line in the batch did not work.
    In this example, I have the Microsoft.Dynamics.GP.IntegrationManager.ini file and the Blank2.imd file in T:\Integrations\dmorinello
    The question is, can I call a Microsoft.Dynamics.GP.IntegrationManager.ini from the batch command also?
    David Morinello
    Senior Developer
    TruckPro LLC
    Cordova TN
  • 2.  RE: Integration Manager - Call the Microsoft.Dynamics.GP.IntegrationManager.ini from a batch?
    Posted 16 days ago
    Edited by Beat Bucher 16 days ago
    Hi David,
    This is an interesting question which I never actually thought off... most of the time, the users just want a shared IM Database.. not an individual one :-)
    I guess you already went thru those articles:
    https://www.gpug.com/communities/community-home/digestviewer/viewthread?GroupId=247&MID=22221&tab=digestviewer&CommunityKey=4754a624-39c5-4458-8105-02b65a7e929e
    https://learn.microsoft.com/en-US/troubleshoot/dynamics/gp/set-the-location-the-dot-imd-dot-mdb-file
    http://dynamicsgpblogster.blogspot.com/2009/09/integration-manager-10-ini-settings.html
    https://www.fmtconsultants.com/changing-integration-manager-ini-file-setting-solves-issue-when-source-file-data-is-incorrectly-integrated-into-microsoft-dynamics-gp/
    http://dynamicbusinesssolutions.ru/gp2010_imhelp.en/imug_ch02_registering1056343.htm
    in particular the last link provides a hint how to use the /ini= parameter to specify the location of the IM .ini file.
