  • 1.  Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 16, 2023 09:27 AM
    I have been moving Integration Manager 2013 integrations to 2018 and have one pair of integrations that hang in 2018.  The same Integrations work ok in 2013
    I then built them from scratch and they still fail. I uninstalled IM and reinstalled, same issue.
    GP 2018 R2 18.00.0727
    I narrowed it down to a script in Mapping. If the script exists, it fails. No script it works but the expected custom distributions are incorrect.
    Event Log
    The program Microsoft.Dynamics.GP.IntegrationManager.exe version 18.0.641.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
     Process ID: e20
     Start Time: 01d9420f758e77dd
     Termination Time: 4294967295
     Application Path: C:\Program Files (x86)\Microsoft Dynamics\Integration Manager 18\Microsoft.Dynamics.GP.IntegrationManager.exe
     Report Id: df6b75db-ae02-11ed-abcc-06f66a63a338
     Faulting package full name:
     Faulting package-relative application ID:
    Thought, comments?
    David Morinello
    Senior Developer
    TruckPro LLC
    Cordova TN
  • 2.  RE: Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 17, 2023 08:10 AM
    Can you share the contents of the script?  I bet there is a connection to another dataset that doesn't match your GP2018 data (i.e. your GP2013 data).
    Director of Business Applications
    Healthmark Industries
  • 3.  RE: Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 17, 2023 08:28 AM
    Below is the Script for the Debit Integration.
    The Credit script is the same except for the first line.
    Account = trim(SourceFields("CM Receivables-Header.GL Account"))
    Store = left(SourceFields("CM Receivables-Header.Customer ID"),3)
    Distribution = ""
    ***Debit  Distibution Script*********************************************************************************
    Account = trim(SourceFields("_DM Receivables-Header.GL Account"))
    Store = left(SourceFields("_DM Receivables-Header.Customer ID"),3)
    Distribution = ""
    Select Case Account
    Case "1INT"
        Distribution = "800-000-13400"
    Case "BDR"
        Distribution = Store + "-000-13410"
    Case "BDRF"
    Case "BDWO5"
    Case "BDWO"
    Case "BDWOC"
    Case "BDWOB"
    Case "BDWOD"
    Case "CAR"
        Distribution = Store + "-000-10000"
    Case "OS"
        Distribution = Store + "-010-51020"
    Case "CCRA"
        Distribution = "800-000-10311"
    Case "CCRD"
        Distribution = "800-000-10312"
    Case "CCRVM"
        Distribution = "800-000-10313"
    Case "CHGB"
        Distribution = "800-000-13404"
    Case "CHGBWO"
    Case "CODR"
    Case "CODWO"
    Case "CE"
    Case "CORER"
    Case "CORWO"
    Case "CW"
    Case "DC"
        Distribution = Store + "-010-44707"
    Case "DELC"
        Distribution = Store + "-000-13402"
    Case "DELR"
    Case "FR"
        Distribution = Store + "-010-54750"
    Case "FSC"
        Distribution = Store + "-010-38100"
    Case "IMPRT"
        Distribution = "800-000-10215"
    Case "INV"
        Distribution = Store + "-000-14200"
    Case "MC"
        Distribution = Store + "-000-13400"
    Case "NSF"
        Distribution = "800-000-13405"
    Case "NSFR"
    Case "NSFSC"
    Case "NSFWO"
    Case "SC"
        Distribution = "800-870-51500"
    Case "SCR"
        Distribution = Store + "-000-13401"
    Case "TE"
    Case "TX"
        Distribution = Store + "-000-23600"
    Case "ZOFF"
    Case "ZSR"
        Distribution = "800-000-10431"
    Case Else
    End Select
    CurrentField = Distribution
    David Morinello
    Senior Developer
    TruckPro LLC
    Cordova TN
  • 4.  RE: Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 17, 2023 08:52 AM
    Hmmm.  No connections.  Are your input files still named CM Receivables-Header and _DM Receivables-Header?
  • 5.  RE: Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 17, 2023 12:28 PM
    Yes
    David Morinello
    Senior Developer
    TruckPro LLC
    Cordova TN
  • 6.  RE: Integration Manager 2018 Scripts causes Error 50001
    Posted Feb 17, 2023 12:47 PM
    Cool.  Next thing...   look at the file definitions (ODBC on the machine?)...   Is the column named "Account" defined as a numeric?  It should be defined as a string.
