Hi Martin,
Depending on how much time, effort, cost and how often this needs to occur, but I might suggest two options:
- SmartConnect (this could provide tons of benefits in other business areas, as well) - allows you to update multiple companies at one time
- Using the eConnect Stored Procedures...create your own procedure where you execute the proc against each of the companies you need to insert/update.
While I love triggers there are definitely a lot of downsides to using triggers (performance, actually firing, upgrades, etc.). I hope you find the right solution for what you are trying to accomplish.
Jamie Evenson
CEO
Najaxa Software
Fargo, ND
Sent: Jul 28, 2022 01:21 PM
Subject: Duplicate item creation in multiple companies
Hi all,
Is there a way to create an item in multiple companies at once? Instead of recreate it for each company.
I saw some posts here about a trigger or a sql script, but is it the only way to do it?
Thank you.
Martin St-Pierre
Humanware Technologies
Drummondville QC
