  • 1.  Changes to Batch Control Totals and amounts in GP 18.5
    Posted Jan 10, 2023 01:41 PM
    I unfortunately do not get into batch posting but a user is commenting to me that after our upgrade to 18.5 she noticed that the Control  Total fields have changed a bit.
    When I did in the past I thought you could enter the batch total(dollars) and count(invoices) and then see those numbers reflected after you enter your last invoice. My user is saying it has changed.
    Howard Blitstein
    Najaxa Software
    Sterling Heights
  • 2.  RE: Changes to Batch Control Totals and amounts in GP 18.5
    Posted Jan 26, 2023 01:24 PM
    Hey @Howard Blitstein
    First check to see if you have a modified version of this window.  You can see that by looking in Administration\Setup\Alternate​/Modified Forms and Reports.
    If you do then you may have to remodify/update the modification of the window for the new version.
    If you don't have a modified window, then use this chat to ping Terry Heley and see if they are seeing that change in the out of the box code at Microsoft.
    Windi
    Windi Epperson
    Customer Support Manager
    Njevity, Inc
    Norman OK
    720-870-9700 x104
  • 3.  RE: Changes to Batch Control Totals and amounts in GP 18.5
    Posted Jan 30, 2023 04:13 AM
    Which Batch window is it?
    dexteritydeveloper
    dexteritydeveloper@gmail.com
