FA posting to the Ledger
  • 1.  FA posting to the Ledger
    Posted Aug 01, 2018 11:06 PM
    How do you change the book ID when you are posting the FA to the Ledger?  We have two book ID's.   I went to the FA setup without much success.
    Brian Marshall
    Assistant Controller
    Thomas Eye Group
    Atlanta GA
  • 2.  RE: FA posting to the Ledger
    Posted Aug 02, 2018 12:30 AM
    Brian,
    In FA setup, you can only have one book as THE book that posts to the G/L. I'm not sure how you could have multiple without doubling up.
    Mind elaborating a bit on what you're looking for?
    Kyle Malone, CPA
    Dynamics GP Administrator - CGB Enterprises, Inc.
    Lead Consultant - http://ALaCarteGP.com
  • 3.  RE: FA posting to the Ledger
    Posted May 15, 2019 02:02 PM
    Our company was recently sold and we had to revalue all of our assets.  So instead of manually adjusting each asset, we thought it would be easier to create a different book to post to our general ledger.  I am currently trying to test this.  However, once I run the Depreciation for the added assets, I go to the Fixed Assets General Ledger Posting window....the Book ID defaults to 1 (which is our current book that posts to the GL).  I want to know how to change that to point to the new book at was created.
    Attached is the screen shot of what I am referring to and I added a box around my "issue" as it won't allow any changes.
    Thanks so much in advance for your help!!
    Ashlie
    Ashlie Carey
    Tidewater Barge Lines
    Vancouver WA
  • 4.  RE: FA posting to the Ledger
    Posted May 15, 2019 02:23 PM
    Hi @Ashlie Carey​/ @Brian Marshall
    @Kyle Malone, CPA
    is correct, only one book posts to the GL in GP - this is in order not to double up depreciation, etc.
    What it looks like you want to do is change the reporting book.
    To do that go to Financial>Setup>FixedAssets>Company and use the drop down to select the reporting book.
    Jo deRuiter, MCP, DCP
  • 5.  RE: FA posting to the Ledger
    Posted May 15, 2019 02:31 PM
    Yeah, I tried that....but it looks the same as our original book that posts to the GL.  I don't know what to do from your screen shot....It appears that our Book 1 and our Book 2 shows the exact same thing.  Book 2 is the new Book we wish to have post to the GL.
    I uploaded both of those screen shots to show that everything looked the same...
    Ashlie Carey
    Vancouver WA
  • 6.  RE: FA posting to the Ledger
    Posted May 15, 2019 02:33 PM
    Hi @Ashlie Carey
    Just select your Book 2 and then run depreciation and your new settings should take effect.​
  • 7.  RE: FA posting to the Ledger
    Posted May 15, 2019 02:46 PM
    oh, yay!  That was easy!  thanks so much!  I greatly appreciate it.
    Ashlie Carey
    Vancouver WA
