Payroll Year-End Close
  • 1.  Payroll Year-End Close
    Posted 2 days ago
    #HRandPayroll #YearEnd
    It looks like I made a boneheaded mistake by not refreshing my memory on the Payroll Year-End Close procedures before I applied the 2021 Tax Update.
    KB -Year-end closing procedures for Microsoft Dynamics GP Payroll
    As you can probably already guess, I neglected to create the Year-End file before applying the 2021 Tax Update.
    Is there anything I should be on the lookout for as we tackle the task of generating W-2s as a result of this oversight?  Is there a workaround without restoring to a backup prior to the install of the Tax Update, which would result in a ton of re-work?  Or, are there published instructions/procedures for situations like this?
    I seem to remember something about resetting the system date to a date in the prior year can help on some issue like this, but am not sure it pertains to this situation.
    We generate about 30-40 W-2s in our organization.
    Ashton Blocker
    Joint Municipal Water and Sewer Commission
    Lexington, SC
  • 2.  RE: Payroll Year-End Close
    Posted 18 hours ago
    Hi Ashton,
    You can roll back the tax tables.  If you use the below link and log into Customer Source, you should be able to download and apply the 2020 tax tables from the CAB file.  It requires the use of SQL so if you are not familiar I'd suggest working with your IT or partner for assistance.
    https://mbs.microsoft.com/customersource/northamerica/GP/downloads/tax-regulatory-updates/tugp2018
    John Kirsch
    GP Product Lead
    Global Optics Inc.
    Green Bay WI
  • 3.  RE: Payroll Year-End Close
    Posted an hour ago
    John,
    Thanks for your suggestion.  I've reached out to our GP partner to help walk us through the steps we need to take, as making edits in SQL isn't something I think we're comfortable with quite yet in our Finance Department.  It's comforting to hear that there is an ability to "roll back" the tax tables in order to get the Year-End Wage File & W-2s printed.
    Ashton Blocker
    Lexington
