Setup GP Analysis cubes
  • 1.  Setup GP Analysis cubes
    Posted Jun 20, 2017 02:10 PM
    I'm trying to complete the installation of GP Analysis Cubes but I'm receiving an error when it get's to the point of creating the data warehouse.
    I have attached screenshots of where I am and the error generated.
    BTW it says I don't have Dynamics database but of course I do.
    The one thing to consider is that I restored the Dynamics and company database to the server I'm setting up for Analysis cubes.
    I'm using GP2015 R2 databases on SQL 2014
    Jeff Roe
    Kele Inc
    Bartlett TN
  • 2.  RE: Setup GP Analysis cubes
    Posted Jun 20, 2017 02:12 PM
    Forgot the attachment
    Jeff Roe
    Kele Inc
    Bartlett TN
  • 3.  RE: Setup GP Analysis cubes
    Posted Jun 21, 2017 10:05 AM
    I don't think restoring creates all the necessary linkages and procedures.  I am pretty sure that what you'll have to do is to delete what you have and create a Dynamics instance from scratch then skip the setup.  Restore from your backups over the top of your DYNAMICS db and any of the production companies you want included in Analysis Cubes.  This will maintain all the critical linkages and allow you to use your production data.  Then when you go to setup Analysis cubes it should work.
  • 4.  RE: Setup GP Analysis cubes
    Posted Jun 21, 2017 10:22 AM
    I actually tried it on a true GP install environment and received the same message. Permissions?
    Jeff Roe
    Kele Inc
    Bartlett TN
  • 5.  RE: Setup GP Analysis cubes
    Posted Jun 21, 2017 05:13 PM
    Issue resolved!
    Crazy Microsoft, should have expected this.
    The problem was that my Dynamics database was proper cased as Dynamics, the install requires the Dynamics database to be upper case DYNAMICS.
    Jeff Roe
    Kele Inc
    Bartlett TN
  • 6.  RE: Setup GP Analysis cubes
    Posted Jun 22, 2017 09:42 AM
    ​So you have a case-sensitive collation in use? That certainly would explain the problems.  We just spent 6 months getting rid of ours because most third-party vendors don't build for it.  Looks like in this case Microsoft didn't build for it either.
    Glad you found the solution.
  • 7.  RE: Setup GP Analysis cubes
    Posted Jun 29, 2017 06:08 PM
    ​I'm getting this error, has anyone seen this?
    ***Fatal Error Encountered***
    Microsoft.AnalysisServices.OperationException: Either the 'MILKY_WAY\lcarrethers' user does not have permission to create a new object in 'DBC-GP2016-T', or the object does not exist.
       at Microsoft.AnalysisServices.Core.AnalysisServicesClient.SendExecuteAndReadResponse(ImpactDetailCollection impacts, Boolean expectEmptyResults, Boolean throwIfError)
       at Microsoft.AnalysisServices.Core.AnalysisServicesClient.Create(IMajorObject parent, IMajorObject obj, ObjectExpansion expansion, ImpactDetailCollection impact, Boolean allowOverwrite, XmlaWarningCollection warnings, JaXmlSerializer serializer)
       at Microsoft.AnalysisServices.Core.Server.Update(IMajorObject obj, UpdateOptions options, UpdateMode mode, XmlaWarningCollection warnings, ImpactDetailCollection impactResult)
       at Microsoft.AnalysisServices.Core.Server.SendUpdate(IMajorObject obj, UpdateOptions options, UpdateMode mode, XmlaWarningCollection warnings, ImpactDetailCollection impactResult)
       at Microsoft.AnalysisServices.MajorObject.Update(UpdateOptions options, UpdateMode mode, XmlaWarningCollection warnings)
       at Microsoft.AnalysisServices.MajorObject.Update(UpdateOptions options, UpdateMode mode)
       at Microsoft.Dynamics.GP.AnalysisCubes.CubesDB.CreateDB()
       at Microsoft.Dynamics.GP.AnalysisCubes.fMain.CreateOLAPCubes()
       at Microsoft.Dynamics.GP.AnalysisCubes.fMain.InstallAnalysisCubesProduct()
    Larry Carrethers
    System Admin/System Analyst
    Dolese Bros. Co.
    Oklahoma City OK
  • 8.  RE: Setup GP Analysis cubes
    Posted Jun 30, 2017 11:13 AM
    ​The error actually says that the object (database) doesn't exist or the user doesn't have privileges to modify the object.  This could also be a case sensitivity issue as "dynamics" and "DYNAMICS" will be the same under a case-insensitive collation but which will be different objects under a case-sensitive collation.
    One thing you might try is to start up SQL Server Profiler and then run the installer.  That way you'll be able to see the exact SQL being sent to the database and you'll be able to see what objects are being examined.
    If you don't have this tool or access to run it, get your DBA to assist.
