Dexterity procedure/function to get the list of fields from a specific window/Form
  • 1.  Dexterity procedure/function to get the list of fields from a specific window/Form
    Posted Oct 30, 2020 09:30 AM
    Hi,
    I am using dexterity as the development platform/environment and was wondering if there is a procedure or function that can retrieve a list of fields from a window/Form like the Window Descriptions in GP?
    I have found in Dexterity function library the set or Resource functions but none of them seem to be able to get a list of fields from a specific window.
    Resource_FillSeriesLIst get a list of Form/Table/Report but not for fields in a specific window
    Resource_GetNthResource will get all fields in dictionary but not for fields in a specific window
    Thanks in advance,
    Tak
    #Technical
  • 2.  RE: Dexterity procedure/function to get the list of fields from a specific window/Form
    Posted Oct 31, 2020 08:11 AM
    Have found the solution from Cross Dictionary Dexterity Development - David Musgrave
    An example of the code is in the project has 2 ways to get the the fields from window/form.
    One way is using system function..
    in integer ProductID; in long FormID; in long WindowID; inout anonymous field FieldListField; // list box inout anonymous field TableListField; // list box system SYS_OLFD_SET_DICT, ProductID; {5084} system 5124, FormID, WindowID, FieldListField, TableListField;​
    Tak Yee Man
    Cogsdale
    Charlottetown PE
  • 3.  RE: Dexterity procedure/function to get the list of fields from a specific window/Form
    Posted Nov 02, 2020 02:11 AM
    Hi @Tak Man
    ​This information is covered in my Pushing the Limits with Dexterity session.
    The link you used was an old out-of-date link, the current link is below:
    https://winthropdc.wordpress.com/2008/07/23/cross-dictionary-dexterity-development/
    More Dexterity Links: https://winthropdc.wordpress.com/dexterity/
