@Nelly Manrique-EellsThe Control Amount should not be a locked field and you can just change it.
Can you change the control amounts? If not, then your IT department has locked that field and you'll have to get in touch with them.
Also, did you check to make sure you entered the batch correctly? The reason to use the control fields is so that you total up what you are about to do to ensure that the amounts will match and be able to troubleshoot if they don't.
🌟 GPUG AllStar 2019
Credential Council Co-Chair
ERP Practice Manager
jo.deruiter@aislingdynamics.com9518674366
Alpharetta, GA
Sent: Feb 15, 2021 09:38 AM
Subject: Account payable Monthly Batch Total Actual amount VS Batch Total Control amount
Good morning Team!
When batch total actual amount does not match the total control amount in a monthly batch. how to fix this problem. We can not post the monthly batch because the actual and control batch do not match.
Thank You for you help
Catholic Human Services
Philadelphia PA
