SOP noninventory negative quantity
  • 1.  SOP noninventory negative quantity
    Posted Mar 12, 2019 11:30 AM
    ​​We would like to use a negative quantity on a non-inventory item in SOP order.  Can that be done?
    We are able to use a negative quantity on a non-inventory item in SOP invoice.  But we want it entered at the order level.
    Linda Binns
    Housley Communications Inc
    San Angelo TX
  • 2.  RE: SOP noninventory negative quantity
    Posted Mar 13, 2019 10:24 AM
    Linda
    I am not sure what you are trying to accomplish with this, but can you enter a positive quantity and simply use a negative Unit Price to generate a negative line item extension? Does that get you to the same place?
    Bill Schulz
    Turnkey Technologies, Inc.
    St. Charles MO
  • 3.  RE: SOP noninventory negative quantity
    Posted Mar 13, 2019 10:57 AM
    Hi @Linda Binns
    We may be of more use if you let us know the business reasoning so we can help with a valid work-around to what you need.
    However, GP, in general, is not a "negative number" application.  It deals only with positive numbers in MOST places.
    Jo deRuiter, MCP, DCP
  • 4.  RE: SOP noninventory negative quantity
    Posted Mar 13, 2019 03:58 PM
    ​We are using KEY2Act with SOP invoicing with Ethotech commissions.  We pay commission on margin.
    We want to Bill our customers for labor and have a set labor cost, so commission are calculated on this line item.
    We have the actual labor cost coming into the SOP order/invoice so the Key2Act Service call will capture the actual cost of the labor, and it is has no commission on this labor item type. And this labor line is not billable, zero unit price.
    We need to reverse the cost that the Billed Labor is sending to Key2Act Service call.
    In order to do that we will need to enter a negative quantity on the labor that is not commissionable but will decrease the labor on the Key2Act and not bill or credit our customer.
    We can do the negative quantity on the invoice and it works, but they would like to have that line on the order.
    Is it possible to put a negative quantity on the order?
    Linda Binns
    San Angelo TX
