Help with logon macro
  • 1.  Help with logon macro
    Posted 17 days ago
    Hi folks,
    We just completed a GP 2018 R2 upgrade to a new server and to support an old add on, we have a workstation that logs in and out automatically every day.  To login, I am using a macro that I had in the old environment but I can't seem to get it to work.  It opens the application but just sits there and doesn't actually log in.  Sometimes I get a second prompt for credentials but that one bails too.
    Did something change, or is there something wrong with the macro?  Any help is appreciated.
    Logging file 'none.txt'
    CheckActiveWin dictionary 'default' form Login window Login
    TypeTo field 'User ID' , '[myuser]'
    MoveTo field Password
    TypeTo field Password , '[mypassword]'
    MoveTo field 'OK Button'
    ClickHit field 'OK Button'
    NewActiveWin dictionary 'default' form 'Switch Company' window 'Switch Company'
    ClickHit field '(L) Company Names' item 1 # '[MyCompany]'
    Karl Pedersen III
    IT Director
    Nye Lubricants, Inc.
    Fairhaven MA
  • 2.  RE: Help with logon macro
    Posted 16 days ago
    Others might spot the problem by eye, but when in doubt, I record it again. At least to compare the old and new.
    https://support.microsoft.com/en-us/help/856496/how-to-use-macros-and-scheduled-tasks-to-automatically-start-the-progr
    David Morinello
    Ascend Learning, LLC
    Leawood KS
  • 3.  RE: Help with logon macro
    I usually change the CheckActiveWin to ActivateWindow commands
    I also use Logging file nul
    Does that help?
  • 4.  RE: Help with logon macro
    Actually in this case the "none.txt" file might give you an important hint as to what is happening. I suspect the user login or the company selection is off just enough to (sneeze) break the Macro.
    David Morinello
    Leawood KS
  • 5.  RE: Help with logon macro
    Posted 6 days ago
    Hi @Karl Pedersen III and @David Morinello
    My friend and fellow ISV @Andrew Dean has worked out the problem and asked me to post the solution. As soon as he mentioned it, I went "Doh" because I should have remembered this too.
    For GP 2018 R2 onwards, a change was made to make the password support 21 characters rather than the original 15 characters. To make this work, a local field called '(L) Password21' was added to the appropriate windows and this is used by the code instead. The original Password field was left on the window as well, so this is why there is no error from the macro, other than it does not work.
    Here is the updated macro
    MoveTo field '(L) Password21'
    TypeTo field '(L) Password21' , '[mypassword]'
    Thanks Andrew for jogging the memory.
  • 6.  RE: Help with logon macro
    Posted 4 days ago
    Thank you gentlemen!  I tried all of your suggestions and was still hitting a wall, but I never got to what probably is the key Mr. Musgrave found in his last comment.  Daniel Johnson from Gravoc reached out to me and helped with the Remember User option that was also grayed out.
    To those coming after, I would definitely recommend trying Dave's suggestion, as getting the script to work for one workstation seems like a better move then enabling a security setting I don't love for everyone, but it was taken as a better solution by the admin
    "If your "Remember user and password" option doesn't work, the setting doesn't save, or if the remember user option is always disabled, check these settings to see if one of them might be the problem. By default, the Remember user and password option is not enabled. You have to enable the option at the system level.  Open Tools -> Setup -> System -> System Preferences and check the Enable Remember User option, then click OK to save the setting."
    Karl
    Karl Pedersen III
    IT Director
    Fairhaven MA
