SQL Update on locked field: Ship to ID/Address ID/Address Code
  • 1.  SQL Update on locked field: Ship to ID/Address ID/Address Code
    Posted Jan 15, 2020 10:20 AM
    We've got an incorrect address ID. Well, actually a bunch of 'em.
    The Address ID field is locked once entered. No editing allowed. No PSTL modification option either.
    In the GP tables the columns are either ADRSCODE (address code) or PRSTADCD (primary ship to address code).
    In some tables they are a primary key.
    A search for the incorrect address ID 'DAV' reveals it's present in 12 tables. It appears a SQL update is the best/only option.
    The update statement below touches each table swapping out one address ID 'DAV' for another 'DVE'.
    This SQL statement appears to be successful in our test database.
    Am I missing something else? Anyone have another preferred update method?
    Highlighted Address ID field
    BEGIN TRANSACTION
    --GP
    UPDATE RM00102 SET ADRSCODE = 'DVE' WHERE ADRSCODE = 'DAV'
    UPDATE SVC00950 SET ADRSCODE = 'DVE' WHERE ADRSCODE = 'DAV'
    UPDATE SY01200 SET ADRSCODE = 'DVE' WHERE ADRSCODE = 'DAV'
    UPDATE SOP10100 SET PRSTADCD = 'DVE' WHERE PRSTADCD = 'DAV'
    UPDATE SOP10200 SET PRSTADCD = 'DVE' WHERE PRSTADCD = 'DAV'
    UPDATE SOP30200 SET PRSTADCD = 'DVE' WHERE PRSTADCD = 'DAV'
    UPDATE SOP30300 SET PRSTADCD = 'DVE' WHERE PRSTADCD = 'DAV'
    UPDATE SY90000 SET PROPERTYNAME = 'DVE' WHERE PROPERTYNAME = 'DAV'
    --SALESPAD
    UPDATE SPCUSTOMERADDR SET ADDRESS_CODE = 'DVE' WHERE ADDRESS_CODE = 'DAV'
    UPDATE SPXCUSTOMERADDR SET ADDRESS_CODE = 'DVE' WHERE ADDRESS_CODE = 'DAV'
    UPDATE SPXSALESDOCUMENT SET XSHIPTOADDRESSCODE = 'DVE' WHERE XSHIPTOADDRESSCODE = 'DAV'
    UPDATE SPXSALESLINEITEM SET XSTORE = 'DVE' WHERE XSTORE = 'DAV'
    COMMIT
    Brad Smith
    SE Retail
    Fountain Inn SC
  • 2.  RE: SQL Update on locked field: Ship to ID/Address ID/Address Code
    Posted Jan 16, 2020 09:33 AM
    The value you want to change for address code is stored under several different column names in core GP including:
    ADRSCODE
    PRBTADCD
    PRSTADCD
    STADDRCD
    SVC_BILL_TO_ADDRESS_CODE
    And covers 100's of tables.
    This does not include third parties.
    If you have a lot to do you are better off first putting the old and new values in a temp sql table with the columns names.
    Something like this:
    IF OBJECT_ID('dbo.zzcolumnchanger', 'U') IS NOT NULL
    DROP TABLE dbo.zzcolumnchanger
    GO
    CREATE TABLE dbo.zzcolumnchanger(
    iUpdate tinyint NOT NULL,
    strColumn varchar(25) NOT NULL,
    iColIsNum tinyint NOT NULL,
    strOldField varchar(35) NOT NULL,
    strNewField varchar(35) NOT NULL
    GO
    Then use a table cursor to cursor the sysobjects to find all table incidents of the columns you provided that way you do not miss any tables.
    DECLARE Table_Cursor CURSOR FOR
    select o.name from sysobjects o, syscolumns c
    where o.id = c.id
    and o.type = 'U'
    and c.name = @Column
    order by o.name
    OPEN Table_Cursor
    FETCH NEXT FROM Table_Cursor into @Table
    WHILE @@FETCH_STATUS = 0
    BEGIN
    And then run your update in the cursor script using the temp sql table with your values.
    Before PSTL this was how everything was updated. After PSTL, now need for things like Address code changes and others that are not in PSTL
  • 3.  RE: SQL Update on locked field: Ship to ID/Address ID/Address Code
    Posted Jan 21, 2020 09:09 AM
    I'll need to include the customer ID to ensure proper targeting of matching address IDs between two customers.
    Thank you so much for this detail response, Thaddeus. Gives me a clear direction to pursue.
    Brad Smith
    SE Retail
    Fountain Inn SC
  • 4.  RE: SQL Update on locked field: Ship to ID/Address ID/Address Code
    Posted Jan 17, 2020 09:49 AM
    I'd check out the Professional Services Tools Library.  It is the safest way to do this (although its going to do exactly what you're doing here).
    And you're probably already doing this, but do this in a test environment first AND do a complete backup in production before you do it there.
  • 5.  RE: SQL Update on locked field: Ship to ID/Address ID/Address Code
    Posted Jan 17, 2020 10:05 AM
    PSTL does not do RM or PM address code changes or combines......  GP2016 and forward
