Can a Voided Check and Invoice be Reversed?
  • 1.  Can a Voided Check and Invoice be Reversed?
    Posted Jan 18, 2019 01:46 PM
    ​​As we are reviewing our 1099 transactions it was found that a 2018 check was voided in 2019 instead of 2018. So, the 2018 1099 amount for one of our vendors is incorrect. I'm not aware of a way to reverse a voided check or invoice. Any ideas? We would also like to change the void date for the invoice. We are on GP2016R2.
    If a SQL script is the only way, please provide the script.
    #Accounting
    Joni Finnell
    GP Projects/Troubleshooter
    Newark OH
  • 2.  RE: Can a Voided Check and Invoice be Reversed?
    Posted Jan 18, 2019 02:43 PM
    HI @Joni Finnell
    If it were me, I'd recreate the original invoice and payment and re--do it all from start to finish.  In this way you are sure that it is correct in all tables.
    Just be careful of the dates - but a complete re-do is how I'd fix this one.
    Jo deRuiter , MCP, DCP
    GPUG Academy Instructor
  • 3.  RE: Can a Voided Check and Invoice be Reversed?
    Posted Jan 18, 2019 02:50 PM
    You cannot reverse a void. I believe you have to use a journal entry to correct, but I'm not familiar with the exact process.
    Mark LeRette
    Application System Analyst II
    Muscatine Power and Water
    Muscatine IA
  • 4.  RE: Can a Voided Check and Invoice be Reversed?
    Posted Jan 21, 2019 09:04 AM
    ​Hi Joni,
    Let me see if I understand. You issued and later voided a check. However, due to the timing difference, the void is in 2019 instead of 2018. This will affect the ledger, and your 1099s. Otherwise the vendor balance is correct. Here is what I would do.
    Issue a reversing GL entry to record the void in 2018 and reverse in 2019. This corrects the timing issue in the ledger. For the 1099 totals, you can adjust the amount that prints, by going to "Purchasing >> Cards >> 1099 Details" and adjusting the amount there, reducing the 2018 total by the amount of the void. You also will probably have the void as a negative amount in 2019, so you would want to fix that.
    Hope that helps.
    Mark Wiley
    Senior Consultant
    DXC Technology
    Akron, OH
  • 5.  RE: Can a Voided Check and Invoice be Reversed?
    Posted Jan 25, 2019 09:46 AM
    Why not just edit the total 1099 amounts instead?
  • 6.  RE: Can a Voided Check and Invoice be Reversed?
    Posted Jan 25, 2019 12:29 PM
    Thanks for your responses everyone.
    I reached out to our GP Partner to fix all of it through SQL. Even the GL part.​ \0/
    A shout out to @Dan Specht at Velosio. He has some mad SQL skills.
    Joni Finnell
    Newark OH
