GP Crashes Upon Logging into Company
  • 1.  GP Crashes Upon Logging into Company
    Posted Jan 08, 2020 05:54 PM
    A user's machine was upgraded in place from Windows 7 to Windows 10.
    When he first experienced a problem, he logged into a company and got the messages shown here.
    We uninstalled GP completely and reinstalled. Same issues.
    The client used Revo Uninstaller and then installed GP again but GP now crashes upon logging in and hitting the home page.
    Does anybody have an idea what could be causing this?
    Charles Allen
    Senior Managing Consultant
    BKD Technologies
    Houston, TX
  • 2.  RE: GP Crashes Upon Logging into Company
    Posted Jan 09, 2020 01:37 AM
    Hi @Charles Allen
    This could be related to Named Printers. Named Printers stores binary printer settings information that is specific to the printer driver installed.  Changing OS is very likely to change the printer driver so that the stored binary data is no longer valid. Attempting to use this binary data from an old driver with the new driver is very likely to cause instability.
    I documented this when I wrote the following KB article:
    https://support.microsoft.com/en-au/help/909739/error-message-when-you-try-to-start-microsoft-dynamics-gp-on-a-compute
    Original Developer of Named Printers.
  • 3.  RE: GP Crashes Upon Logging into Company
    Posted Jan 09, 2020 09:01 AM
    Hi Charles,
    I recently had a client upgrade 2 pc's from Windows 7 to Windows 10.  GP 2016 launched as it should on one but would freeze at the home screen on the other.  I did similar troubleshooting steps that you did (a repair, a full install, removed security, even tried opening up IE security).  We finally found that the pc that worked was updated to Windows Update 1909.  The pc that was failing was only on Update 1709.  Updating the pc to Windows 1909 fixed GP for us.  Hope this helps.
    Dale
    Dale Stratton
    Dean Dorton Allen Ford, PLLC
    Lexington KY
  • 4.  RE: GP Crashes Upon Logging into Company
    Posted Jan 09, 2020 09:30 AM
    The client installed some Windows updates and the issue was resolved.
    Charles Allen
    BKD Technologies
    Houston, TX
  • 5.  RE: GP Crashes Upon Logging into Company
    Posted Jan 09, 2020 11:26 AM
    Edited by Lou Spevack Jan 09, 2020 11:28 AM
