Unable to sae to the batch activity table
  • 1.  Unable to sae to the batch activity table
    Posted May 10, 2018 04:51 PM
    We had a user that was trying to post her EFT Remittance and received the error that said
    "Unable to save to the batch activity table.  You will not be able to use this batch"
    After looking into it, the payments were showing on the vendor card as "work"
    I went into the Process Payables Remittance screen with my user id and I was able to post the batch just fine.  We cant see any other issues as of now and everything seemed to process like normal but my question is if it did something behind the scene we should be worried about.
    Katie Pieczynski
    Accounts Receivable Manager
    DANSR
    Champaign IL
  • 2.  RE: Unable to sae to the batch activity table
    Posted May 10, 2018 05:01 PM
    ​Hi @Katie Pieczynski
    There is not necessarily any reason to worry with just one instance that seems like it was easily recoverable.
    If it happens again or if you see any other warnings or errors like that I would contact your partner.
    These things happen, and often, with no tragic underlying causes.  It's only if it happens regularly that there may be something to worry about.
    Member, GPUG GP Credentialing Exam Committee
    "......what isn't she up to?"
    Milwaukee, WI
  • 3.  RE: Unable to sae to the batch activity table
    Posted Nov 10, 2020 07:20 PM
    Just to add to Jo's response, when you see this message, take a look at the SY00800 table in Dynamics.  You'll see two records with the same batch, but the WINTYPE on one of them will be "0" (zero), which is not valid.  If the user were to close GP and open it again, that would remove the bad record.  Or, since this is a temp table, you can delete that row, and the user will be able to save the transaction and/or the batch.  See an explanation of the different wintype's in https://www.gpug.com/communities/community-home/digestviewer/viewthread?GroupId=247&MessageKey=f4d742a1-1f94-4e21-a245-fd83f8a19235&CommunityKey=4754a624-39c5-4458-8105-02b65a7e929e&tab=digestviewer.
    Merri Gorrell
    Business Applications Support
    Heska Corporation
    Loveland CO
