Report Writer
  • 1.  Report Writer
    Posted Sep 28, 2017 10:35 AM
    I need to make a change on the template that is used on orders and quotes. I have not used report writer before, and want to know how I go about it. We are using GP 2015.
    Chase Landorf
    Inventory Control & Accounting
    Saint Augustine FL
  • 2.  RE: Report Writer
    Posted Sep 28, 2017 12:56 PM
    Are you using Report Writer reports or Word documents? If you are using Report Writer reports, make sure your reports.dic is pointing to your local computer that way you don't risk breaking the one in production. Once your changes are final and have been tested, then you copy your local reports.dic to the one in production.
    Christine Boisvert
    IT Manager
    Floform Countertops
    Winnipeg MB
  • 3.  RE: Report Writer
    Posted Sep 28, 2017 02:30 PM
    @Chase Landorf,
    Your question is a bit broad for a Forum! If you've never used Report Writer before, then you'll need to get some training. Forum responses will ultimately be unsatisfying because Report Writer is a very large topic.
    "Sparkly" Steve Erbach - Business Analyst & MS Dynamics Platform Administrator
    WOW Logistics Company - Appleton, WI
    VP for Communication, emeritus, GPUG WI (Milwaukee) Chapter
    GP 2016 (16.00.0439) / MR 2012 CU15
    Welcome to Dynamics!
    You do not have permission.
    Call Steve.
    (hat tip: Lou Spevack)
  • 4.  RE: Report Writer
    Posted Oct 09, 2019 09:34 AM
    How do you update columns in report writer
    Anwar Abdel-Aziz
    University of Maryland Faculty Physicians, Inc.
    Baltimore MD
  • 5.  RE: Report Writer
    Posted Oct 09, 2019 01:41 PM
    Hi Chase,
    Here's the link to the Report Writer manual...
    • Microsoft Dynamics GP 2013 Tools Documentation: Report Writer
    https://www.microsoft.com/en-us/download/details.aspx?id=36228
  • 6.  RE: Report Writer
    Posted Oct 11, 2019 02:01 PM
    Hey @Chase Landorf
    Welcome to the nightmare that is ReportWriter Reports.  For what it is worth, I would follow Ms @Christine Boisvert's suggestion about not mucking up your existing reports by pointing the .set file on your local GP Install to a local folder for modified reports before embarking on this.
    In a nutshell, to use an RW report to update a template, you modify the RW Report, save it and then select to utilize that report in Alternate/modified forms and reports.
    Print the new STANDARD report to a File, and XML file, that is, then you go about creating a copy of the out-of-the-box Word Template, click modify there then when it opens in word go to the Developer Tab (You'll need GP's Word Add-In Installed) and then remove the current source of the template and add your new XML file as the template source.
    Now, format the template, save it into the templates, make it the default and there you are!
    I'm teaching a class on this next Tuesday morning at Summit!  See if you can attend, but here's a screenshot from a slide:
