not privileged to run this report
  • 1.  not privileged to run this report
    We have an end user testing EFT and they get the messaged "not privileged to run this report" but the process seems to complete. We however do not get the report and I'm not sure what's the report name. It seems it's a permissions issue which I'm thinking could be solved by going to Tools>>Setup>>System>>Alternate/Modified Forms and Reports, just not sure what to do next. Thanks for any suggestions!
    Eddie Madera
  • 2.  RE: not privileged to run this report
    Hi Eddie,
    You are correct... this is a report access issue... and there's a need to identify what the report in question is.
    Would you be able to provide the detailed steps taken by this user - and when exactly in the process is he the report being generated (and / or getting the error message)?
  • 3.  RE: not privileged to run this report
    @Eddie Madera
    A not privileged error is caused by security access (security tasks and roles).  Alternate/Modified Forms and Reports just controls which version you use ONCE you have access.
    You need to identify the security issue, the simplest method is to use the Security Profiler window in GP Power Tools.
    Install the 30-day free trial and then​ use the Security Profiler to identify the report and the Security Information window to fix the issue.
  • 4.  RE: not privileged to run this report
    Does anyone have an idea why GP doesn't provide you the name of the resource in the access denied dialog? Seems like such a simple thing...
    Matthew Arp
    Business Systems Developer
    Hunton Group
    Houston TX
  • 5.  RE: not privileged to run this report
    Hi @Matthew Arp
    GP Power Tools adds the details to the dialog by default for forms. Sadly the technique does not work for reports as the dialog text cannot be altered the same way I can for forms.
    But the Security Profiler will capture the details.
    David​
  • 6.  RE: not privileged to run this report
    Hi Eddie,
    Just another thought... use the 'sa' login for the test run so that all reports get generated... then re-run it as the other user.
    This way, you'll be able to note which report/s didn't get printed for the other user.
