  • 1.  SOP Autoallocation not writing results to the table correctly
    Posted 25 days ago
    I have an instance where i had a part with a quantity of 2 on backorder and an SOP order with 2 on backorder.
    When the SOP autoallocation ran it showed on the report that the part was associated with the order as expected and showed that the backorder went from 2 to 0 and the quantity allocated went from 0 to 2. All show as expected on the report for the part and the order.
    When I look at the order and the part in GP it is showing a backorder of 0 and the allocated quantity as 0 (should have been 2).
    In this case the Autoallocation reported a correct result but the actual sop10200 table was not updated correctly.
    Any ideas?
    Jeff Roe
    Kele Inc
    Bartlett TN
  • 2.  RE: SOP Autoallocation not writing results to the table correctly
    Hi Jeff,
    Did you try to run a quick reconcile on that particular item number ? sometimes GP's allocation has some hiccups and the numbers don't update everywhere..
  • 3.  RE: SOP Autoallocation not writing results to the table correctly
    Thanks for this information!
    marlas Stinson
    Noca+
    Москва
  • 4.  RE: SOP Autoallocation not writing results to the table correctly
    Edited by marlas Stinson 8 days ago
    An IT consulting service is an excellent choice for businesses. An IT consultant can manage various IT functions and help generate sales. It can also help manage security and compliance issues https://mlsdev.com/blog/top-custom-software-development-companies. Further, an IT consultant can handle software testing and security. Moreover, a software development service can handle a wide range of other tasks for your business. The IT consulting firm can also provide you with technical support. A customer relationship management system is crucial for a business. A CRM is a valuable tool that allows you to stay connected with customers.
    marlas Stinson
    Noca+
    Москва
