Duplicate Fixed Asset
  • 1.  Duplicate Fixed Asset
    Posted Nov 26, 2019 11:01 AM
    I discovered an Asset that has been recorded twice under two separate FA ID #'s.  I need to reverse the depreciation and delete the duplicate asset.  Can someone tell me the best way to do this?  ​
    Diane Fangman
    Accounting Manager
    Meridian Technologies
    Jacksonville FL
  • 2.  RE: Duplicate Fixed Asset
    Posted Nov 26, 2019 01:08 PM
    Edited by Gerald Buenafe Nov 26, 2019 01:10 PM
    Hi Diane,
    If the intention is to delete the asset (via Delete Asset Utility*), then GL adjustments need to be entered.
    * This just erases the asset records from the Fixed Assets module only, and does not reverse the entries made in GL
    On a side note, you may opt to go through the following as these will simplify the GL reversal:
    1. Undo Depreciation
    2. Retire the Asset
    Once done, before deleting the asset, make sure to run the FA-GL Posting routine to generate the FATRX batch in GL.
    Assuming all the depreciation records are reversed and the retirement has been done, the Depreciation, Accumulated Depreciation and Asset Cost entries will be reversed. The adjustment will be between the FA Clearing and the Gain/Loss accounts.
    For reference, here is the data for a 'simple' asset:
    1. Added the asset on 2/1/2027
    2. Depreciated the asset until 4/30/2027
    3. Backed out depreciation to 2/01/2027
    4. Retired the asset on 2/1/2027
    Gerald Buenafe
    Owner/Consultant
  • 3.  RE: Duplicate Fixed Asset
    Posted Nov 26, 2019 05:29 PM
    Very Helpful! Thank you!
    Diane Fangman
    Accounting Manager
    Jacksonville FL
