  • 1.  Server Admin Mail
    Posted Sep 07, 2017 03:09 PM
    We are having issues with our Server Admin Mail. Below is an image of the result of a PowerShell test command that failed.
    Can someone help me?
    PowerShell Test failed
    Josue Rivera
    System Administrator
    Ti-SALES, Inc.
    Sudbury MA
  • 2.  RE: Server Admin Mail
    Posted Sep 08, 2017 08:16 AM
    The error is simply saying that whatever certificate the mail system is presenting could not be validated. There are several options:
    • Specify that the connection should not be encrypted, you'd probably need to change the port number you're connection to
    • Correct the certificate so that it can be validated
    • Tell powershell to ignore SSL validation, I know this works for WebClient (HTTPS requests), I would imagine that it should also work for Mail connections. [System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$true} ;
    Matthew Arp
    Business Systems Developer
    Hunton Group
    Houston TX
