Report for Vendor volume
  • 1.  Report for Vendor volume
    Posted 17 days ago
    I need a report to run that will give me transaction level info for Vendor Volume for a range of time
    Betty Hall
    Powell Christensen inc
    Richland WA
  • 2.  RE: Report for Vendor volume
    Posted 17 days ago
    Edited by Mark LeRette 17 days ago
    Have you tried the Transaction by Vendor Inquiry under Purchasing?
    You can run the Inquiry by Vendor ID for a document date range.
    You can then select a transaction from the list returned and click the Document Number link to drill down to the Transaction Inquiry Zoom window,.
    Mark LeRette
    Application System Analyst II
    Muscatine Power and Water
    Muscatine IA
  • 3.  RE: Report for Vendor volume
    Posted 16 days ago
    I'd recommend a SmartList. I utilize one for a similar report for my auditors. I use a Payables Transaction SmartList that pulls in Vendor ID, Name, Document Type, Document Date, Document Number, Document Amount, Transaction Description (and add whatever else you need). I then choose Search and search the Document Date column for the date range I'm looking for. You could also do a filter on the Document Type column if you only wanted payments, or invoices, etc.
    I then dump the data into Excel and use a Pivot to summarize by Vendor ID to get totals.
    Tiffany Ziegler
    Vice President & Controller
    Velcor Leasing Corporation
    Madison WI
