Sales Batch Totals Not Correct
  • 1.  Sales Batch Totals Not Correct
    Posted May 08, 2019 09:21 AM
    ​We are having a situation that started intermittently a couple of months ago and is now happening on a rather frequent basis.  When we are doing invoicing through SOP, we have been noticing that the Batch Totals (number of trx and $$) do not match what is actually in the batch.  If you run the edit list, all transactions are in the batch and the totals at the end of the report tie to what we are invoicing, however the Batch Totals at the top of the Edit List are incorrect.
    I have tried running check links and reconciling the batches and that still does no good.  I had someone say that is sometimes will happen when there are transactions that are imported into GP.  We do import some transactions occasionally but this happens whether or not there are imported trx in the batch.
    Does anyone have any ideas?  We are on GP 2010 and are going to upgrade soon.  Do you think the upgrade might resolve the issue?
    Jeff
    Jeff Stowe
    IT Application Analyst
    Multiplan, Inc
    Sarasota FL
  • 2.  RE: Sales Batch Totals Not Correct
    Posted May 08, 2019 10:41 AM
    Hello Jeff.
    I was wondering if your batch totals on the batch page happen to be exactly twice the amount of your batch total on the transaction page..
    If it is exactly twice as much then it is correct since it adds the Debit and Credit columns to get the Batch Total.
    I was just curious if this the issue.
    Steve
    Steve Burney
    Senior Systems Architect
    Lebanon, TN United States
    steve.burney@us.nitco.co
    GPUG Ruby Award 2018
    GPUG All Star 2017
    Twitter @SteveBurney
    GP2016 R2
    MRCU14
  • 3.  RE: Sales Batch Totals Not Correct
    Posted May 08, 2019 11:12 AM
    ​Hi Steve, no the number of trx is incorrect (usually by 1 or 2) and the amount is off by what the total would be of the 1 or 2 trx.
    Jeff Stowe
    Multiplan, Inc
    Sarasota FL
  • 4.  RE: Sales Batch Totals Not Correct
    Posted May 08, 2019 11:03 AM
    Hi @Jeff Stowe
    This is likely an issue with the Report Writer report you are using and it sounds like the Edit List for that transaction was likely modified and is now not correct.
    To test, go to Administration>Setup>System>Alternate/Modified forms and reports
    Pull up the ID that your user is assigned to, select "Reports", Go to the edit list that is not working and change it back to GP out of the box.
    Then, go to the batch, print the edit list again.  If it is now correct then the issue is the math on the modified report.
    Jo deRuiter, MCP, DCP
  • 5.  RE: Sales Batch Totals Not Correct
    Posted May 08, 2019 11:15 AM
    ​No we don't use a modified report for the Edit List.  The problem isn't just with the Batch Totals on the Edit List, if you bring the batch up in the "Sales Batches" window, the No of Trx and the Batch Total is incorrect there as well.  Sometimes it's fine on the Sales Batch window and when it is it is fine on the Edit List as well.
    Jeff Stowe
    Multiplan, Inc
    Sarasota FL
  • 6.  RE: Sales Batch Totals Not Correct
    Posted May 09, 2019 07:56 AM
    Jeff,
    Given the above responses, I bet your issues lies in your import or some related 'feature' of your import.  What is your import (an ISV, Integration Manager, home-grown code, etc.)?
    It sounds like this is a nuisance and not impacting your processing.  You may remedy it with your upgrade.
    I would take a careful approach with your upcoming upgrade and scrutinize every step of bringing up your new environment (assuming you are not doing an in-place upgrade and will be bringing up a new environment).
    Try to find the steps and conditions in your current environment that cause this to be in a position to replicate it on-demand.  If you can replicate it, then, do those steps after each install of your new environment (install GP, import customizations, install ISVs, etc.).  You might catch the offending ISV or customization.
    If it does it right after installing GP and before the customizations and ISV's, I bet you've got a rogue trigger in your database.  There are a variety of ways to identify these.  I like to write triggers that capture every time that the field is updated and why and by which user.
    I hope this helps.
    Healthmark Industries
  • 7.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 09:37 AM
    Edited by Lisa Levendusky May 16, 2019 09:38 AM
    I just found this thread, as we are having the same problem.  This is the first time we've had this issue.  Our "Batch Total Actual" is $4276.00, and the total of the entries is $3956.00.  This is a recurring batch, if that makes any difference, and changes are made manually.
    Lisa Levendusky
    Exceptional Persons, Inc.
    Waterloo IA
  • 8.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 10:26 AM
    Hi @Lisa Levendusky and @Jeff Stowe
    Out of further curiosity, do either of you have a third party product installed and/or is GP totaling taxes for you?​​​
  • 9.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 10:40 AM
    No to both of those questions.  Our edit report does not match itself.  We've run check links on open receivables.
    Lisa Levendusky
    Waterloo IA
  • 10.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 11:46 AM
    Hi @Lisa Levendusky
    Can you send along the very bottom row of the Edit List, that should look something like this?
  • 11.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 03:10 PM
    Great Plains typically does not recalculate the batch total from all the transactions when the total is updated, it simply adds the transaction amount to the total.  An environmental problem, power outages, etc., can cause the batch total to go out of balance. I have never seen this to cause a problem, the batch total on the batch report is what gets posted, so I would just post the batch.
  • 12.  RE: Sales Batch Totals Not Correct
    Posted May 16, 2019 03:40 PM
    @Jo deRuiter  Here are the totals from the bottom.  ^^
    Apparently there was one entry for $320.00 that was deleted, and that's the difference between the two #'s.  ​​So, @Bruce Strom, you're saying that it's safe to post?​​  Maybe that entry just didn't get deleted from the batch total?
    Lisa Levendusky
    Waterloo IA
  • 13.  RE: Sales Batch Totals Not Correct
    Posted May 17, 2019 11:01 AM
    We went ahead and posted the batch, and it posted correctly.  Thanks for your help!!
    Lisa Levendusky
    Waterloo IA
  • 14.  RE: Sales Batch Totals Not Correct
    Posted May 23, 2019 05:28 PM
    Bruce, I believe that you have identified out problem.  They are adding and changing things in the batches constantly.  I'm going to tell them not to look at the Batch Window but to check the Edit List instead.  Ultimately, we haven't really been off anywhere in Sales or Receivables so that must be what is going on.
    Jeff​
    Jeff Stowe
    Multiplan, Inc
    Sarasota FL
  • 15.  RE: Sales Batch Totals Not Correct
    Posted May 24, 2019 09:46 AM
    I know this is a few days old...but here are my thoughts:
    The Edit list only prints Returns + Invoices. The Batch Total on the Batch screen includes Quotes, Orders, and Back Orders. Those are not on the Edit List because they do not post.
    To see all transactions in the batch, run a Batch List:
    Batch List SOP
    Amber Bell
    Training Dynamo LLC
    Twitter: @trainingdynamo
