SmartConnect error taGLTransactionLineInsert
Jump to Best Answer
  • 1.  SmartConnect error taGLTransactionLineInsert
    Posted Apr 30, 2020 03:36 PM
    Hi all,
    I'm using a SmartConnect journal entry (financial) map per GP company and one map is throwing a strange error:
    SmartConnect Error
    The map was originally created using the Duplicate Map option, then changing the Company to import to.
    I am also using a GP Rolling column for the Journal Entry Number, so I changed the company that the GP Rolling column is pointing to as well.
    I also tried creating the map the old-fashioned way - from scratch - same result.
    The GP company is only used for quarterly/year-end entries and I can manually create journal entries without issue.
    We're on SC version 20.16.1.24, with GP 2016 R2.
    Thanks in advance!
    Jeff
    Jeff Pfershy
    Sr Business Analyst
    BluJay Solutions Inc
    Holland MI
  • 2.  RE: SmartConnect error taGLTransactionLineInsert
    Posted May 01, 2020 11:53 AM
    Jeff,
    Many times this is a permissions issue with the user running the map.  I don't know who you are setup to run as, but does the user have the same permissions in both companies?
    You can also take a look at this Tech Tuesday on the issue with the common causes for this error.
    https://www.eonesolutions.com/tech-tuesday-unable-to-retrieve-the-next-number-in-the-sequence/
    Let us know if that doesn't resolve it.
    Nicole Albertson
    Product Manager
    eOne Solutions
  • 3.  RE: SmartConnect error taGLTransactionLineInsert
    Posted May 04, 2020 05:21 PM
    Hi @Nicole Albertson - Thanks for replying. I couldn't spend any more time on it last week so just used copy/paste to get the FY year-end JEs into the companies.
    I'll take a look - I know we have a specific SmartConnect user - it may not have the correct SQL rights so I'll check that out.
    Also, I don't recall having to run System Maintenance in SC in the past and we have a lot of custom integrations running 24/7 - what's the risk involved in running this process? We have 49 GP company databases.
    Jeff
    Jeff Pfershy
    Sr Business Analyst
    Holland MI
  • 4.  RE: SmartConnect error taGLTransactionLineInsert
    Best Answer
    Posted May 04, 2020 05:36 PM
    Hi Jeff,
    Check if this stored procedure [E1_SC_GetNextNumber] is in the Company that you were integrating to.  If not, just copy it from another company that has it and run it to the company.
    Gerald Buenafe
    Owner/Consultant
  • 5.  RE: SmartConnect error taGLTransactionLineInsert
    Posted May 13, 2020 11:25 AM
    Hi @Gerald Buenafe,
    You were correct - all of the "E1_SC_" stored procs were missing in this relatively new GP company - I scripted them out, added a GRANT statement and ran it against each of our company databases. Many of our newer databases didn't have these SPs.
    Worked like a charm - Thanks!
    Jeff Pfershy
    Sr Business Analyst
    Holland MI
