Formatting Fill Columns
  • 1.  Formatting Fill Columns
    Posted Jul 29, 2020 03:23 PM
    Hello All,
    I am fairly new to Management Reporter so please forgive anything I am missing in this post, but I am trying to create a set of financials.  Each financial report will compare 3 locations and multiple entities per location side by side.  I formatted the reports replicating the format we typically use in Excel, but I am having trouble with the fill columns.  I would like to have a blank fill column between each location, but I the formatting I have also formats the fill columns.  Is there a way to have the formatting skip over a fill column?
    In this example, you can see the fill column between location 1 & location 2 has " - " because I have the description columns underlined, and then the blue formatting extends through the fill column as well.
    Ideally I would like to eliminate the " - " and have the blue formatting stop at the location 1 total column and restart with entity 1 of location 2.  The same goes for the box around the blue lines.  I have manually edited the formatting in the example below:
    Evan Ross
    CCI
    Chicago IL
  • 2.  RE: Formatting Fill Columns
    Posted Jul 29, 2020 07:59 PM
    Edited by Beat Bucher Jul 30, 2020 10:45 AM
    Hi Evan,
    I'm no expert in building reports in MR2012, but if not mistaken, there is a formula called "NP" for No Print when a cell contains zero value..
    Please check the documentation about MR.. that should be described in there.
    Edit: sorry, completely missunderstood the question :-(
    ignore my answer :-)
  • 3.  RE: Formatting Fill Columns
    Posted Jul 30, 2020 05:39 AM
    Evan,
    There is a "Fill" type you can use in the Column Formats and this should work.  You can take the default and in the column width you can set the amount of spaces for this column.
    Another option would be to set the amount of spaces to leave blank before printing the first column for Entity 1/Location 2 and that would also give you that spacing.
    The issue with the line formatting is a bit tricky as the format in the row extends across all columns.  You will probably need to do a couple of line rows and reference both to the total row so it shows in the logical location and then use the column restriction to limit what columns that line should print in.
    David Callery
    Coe & Company, LLC
    Jefferson LA
  • 4.  RE: Formatting Fill Columns
    Posted Jul 31, 2020 01:06 AM
    There is the "Extra Spaces Before Column" you may use (instead of the FILL column type.  The Report Definition default is 2 spaces between each column and then in the Column Definition is where you may add extra spaces.  See screen shots below.
    Hope to see everyone at Summit conference virtually where MSX Group will be presenting several tips and tricks sessions on Management Reporter and teaching pre-conference Academy classes.  Happy reporting and budgeting and have a nice day/weekend ALL!!!
    Derek Krebs
    Sr Consultant, MSX Group
    PROSPERO by MSX Group, www.msxgroup.com
    Derek.Krebs@msxgroup.com
  • 5.  RE: Formatting Fill Columns
    Posted Jul 31, 2020 08:41 AM
    Hi Derek,
    That seems to work when viewing the report with the Management Reporter Viewer, but then once I export to Excel, the extra spaces before columns does not carry over.  Is it possible to include the extra spaces before column in an export into Excel?
    Evan
    Evan Ross
    CCI
    Chicago IL
  • 6.  RE: Formatting Fill Columns
    Posted Jul 31, 2020 08:40 AM
    Hi David,
    I already have a fill column, but the formatting extends through the fill column.  Is there a setting you have to check to have the format stop before the fill column and start again after it?
    Evan
    Evan Ross
    CCI
    Chicago IL
