Manufacturing Reverse Issue
  • 1.  Manufacturing Reverse Issue
    Posted Apr 24, 2020 08:34 AM
    Hey Everyone,
    We are having a big issue where about 1 in 3 of our reverse issues in manufacturing have started to fail.  It seems out of the blue so we are stumped.  We do these 15 times a day with previously no issue.  I have attached a copy of the inventory report that says 'error'.  its like it cant find inventory when it goes to do the reversal.  It successfully removes from the MO but it does not do the inventory side.  When I run a reconcile of inventory it puts the item back on the MO.  Any help or ideas would be greatly appreciated.  We have worked with our partner and MS to try to find corrupted records which we thought were the issue and removed some, no change.  The weird part is that some of these fail in test company and work in live and reverse.  We cant seem to find a pattern.  We have other GP companies and no issue with their MOs.  If anyone has any suggestions at this point we would gladly try it.  Thanks!
    -Rick
    @Wally Dodds
    @Dan Abernathy​​​
    Rick Heinrichs
    Sr. IT Analyst
    Liburdi Engineering Limited
    Hamilton ON
  • 2.  RE: Manufacturing Reverse Issue
    Posted Apr 27, 2020 05:12 PM
    ​Hi Rick,
    Are any of the initial Issue trx or the Reverse Issue trx being integrated in or are they all done manually via the GP UI?
    Are you using serial/lot and/or multibin?
    Sunny Mattoon
    Sr. Implementing Consultant
    Columbus Global
    Portland OR
  • 3.  RE: Manufacturing Reverse Issue
    Posted Apr 28, 2020 08:46 AM
    Hey Sunny
    They are all through the GP UI.  We use serial/lots but not multibin.  Thanks
    Rick Heinrichs
    Sr. IT Analyst
    Hamilton ON
  • 4.  RE: Manufacturing Reverse Issue
    Posted May 08, 2020 11:33 AM
    Just an update for future reference, there was a failed comp trx entry and it left a whole bunch of pending quantities in the M0P1027.  cleared those out and all is good.
    Rick Heinrichs
    Sr. IT Analyst
    Hamilton ON
  • 5.  RE: Manufacturing Reverse Issue
    Posted May 08, 2020 11:38 AM
    I wondered.
    You might want to keep an eye on MOP1020 too.  That is only supposed to be unposted issue/reverse issue and MO receipts.  However, things get left behind and cause all sorts of strangeness.
    Best Regards,
    Sunny Mattoon | CPIM | Dynamics Advanced Credentialed Professional
    Sr. GP Implementation Consultant
    Phone: 651 746 1774 Mobile: 971 275 6578
    E-mail:
    SUNM@columbusglobal.com
