Financial Group Reports
  • 1.  Financial Group Reports
    Posted Mar 25, 2020 01:32 PM
    Does anyone  know if it's possible to print financial group reports directly to a pdf file rather than having each one come up on the screen and then save it as a pdf?
    Thank you -
    [SANDY] [BROWNER] [CPA]
    [CONTROLLER]
    [COLORADO AGRI PRODUCTS, LLC]
    [STERLING] [CO]
  • 2.  RE: Financial Group Reports
    Posted Mar 26, 2020 08:50 AM
    Sandy,
    Each one of those pdf are separate files. You can merge them after they print to pdf using Adobe acrobat DC or the tools in the Adobe's creative cloud.
    Jeff Strait
    Jeff Strait
    St. Augustine FL
  • 3.  RE: Financial Group Reports
    Posted Mar 26, 2020 09:26 AM
    ​Our It department has setup printer for us to select, Adobe PDF and Microsoft Print to PDF that we can choose when we print.
    Linda Binns
    Housley Communications Inc
    San Angelo TX
  • 4.  RE: Financial Group Reports
    Posted Mar 26, 2020 04:33 PM
    Hi Sandy,
    Consider Reporting Groups in GP like a batch printing of multiple reports.. The final output goes where the default output is set for each report in the group.. If some of the reports are defaulted out to the screen, then that's where they going to show up when printing the report group.
    You have to open individually each of the report destination option of every report that's part of the group and make sure it either prints to "printer" or "file".
    If you're luck enough and have Adobe Acrobat Writer installed on the system, then you may see an additional format in the "File" output format options, which would allow you to save as PDF directly. When using a PDF "Printer" queue, the system is going usually to prompt you for a file name to each report output.. not very practical, especially if your report group is large and contains multiple reports. GP unfortunately doesn't even suggest a default report name in the file output box..
