Hi All
Check the paper size settings for the default printer in Windows.
If you are using Named Printers, check the paper size settings for the printer definitions.
The report writer reads the paper size and margin sizes from the printer driver settings before printing a report and this error would be because the paper size or non-printable margin information is incorrect.
Original developer of Named Printers
http://www.winthropdc.com------------------------------
Sent: Dec 02, 2019 06:19 PM
Subject: Error Printing page length is shorter than page header + page footer
Hi Carlos,
I agree... If the Windows 7 user and Windows 10 user are using different default printers - then it may be a printer issue.
See if assigning the Windows 7 printer as the default printer of the Windows 10 user helps...
Gerald Buenafe
Owner/Consultant
Sent: Dec 02, 2019 01:49 PM
I don't have an exact answer, but I did a bit of searching online about this. It seems that users can encounter this error when they either do not have a default printer assigned or if their default printer is set up to print on different size paper than the report requires. Check on your users' printer setup, maybe a change there could resolve the issue.
Sarah Brewster
Implementation and Support
ActivReporter by nQativ
Lubbock TX
Sent: Dec 02, 2019 12:32 PM
When a user prints a report within GP they receive the error "page length is shorter than page header + page footer" and from that point the system will not print the report. The only way to clear the error is restart computer and when the reprints it works.
This is happening on windows 10 pro. The user that are using windows 7 does not get the error message.
Thanks for any help.
Carlos Cockerham
IT Manager
Southland Printing Company
Shreveport LA
