Management Reporter cannot export to Excel from Web Viewer
  • 1.  Management Reporter cannot export to Excel from Web Viewer
    Posted 21 days ago
    Good morning GPUG!
    We are having an issue where we cannot seem to export to Excel from Web Viewer. We can do it from Report Viewer though. The message I'm seeing when the file tries to open in Excel are:
    Sorry, we couldn't open 'http//XXXXXXXXX'.
    Then I get
    Microsoft Excel cannot access the file http://xxxxxxx for several possible reasons:
    -The file name or path does not exist
    -The file is being used by another program
    -The workbook you are trying to save has the same name as a currently open workbook
    Has anyone run into this before?
    Tammy DeStefano
    Phigenics, LLC
  • 2.  RE: Management Reporter cannot export to Excel from Web Viewer
    Posted 21 days ago
    What version browser are you using?
    Mark LeRette
    Application System Analyst II
    Muscatine Power and Water
    Muscatine IA
  • 3.  RE: Management Reporter cannot export to Excel from Web Viewer
    Posted 20 days ago
    Hi ​Tamara,
    What is your MR 2012 build version  (cu) ?
    And yes, which browser do you try to use ?
    Do you try to export directly from the Web MR Viewer or is the link provided thru an e-mail ?
  • 4.  RE: Management Reporter cannot export to Excel from Web Viewer
    Posted 20 days ago
    ​Do the reports include financial and transaction details?  I've got the same issue, but I CAN export from web viewer if I don't include the transaction details.
    David Helms
    Vice President of Accounting
    Morningstar Properties, LLC
    Matthews NC
  • 5.  RE: Management Reporter cannot export to Excel from Web Viewer
    Posted 5 days ago
    Thanks for the feedback all.  To provide more info. MR is version is 2.12.16003.25.  We use IE and it is version 11.0.0600.19180.
    This issue started after we upgraded to GP2018R2. The IE version was the same as it was when it was working with GP2015.
    I tried build a simple report and it will not export to excel either.
    When I select Open from the Open/Save/Save As window, I get these two messages:
    When I select Save or Save As from the Open/Save/Save As window, I get these messages:
    If forces me to change the file name. In this I changed it to "test". Then I get:
    We run on a terminal server and all users are having the issue. It seems like there is a setup issue, but I can't seem to figure out what is missing.
    Any help would be appreciated.
    Tammy
    Tamara DeStefano
    Phigenics, LLC
  • 6.  RE: Management Reporter cannot export to Excel from Web Viewer
    Posted 20 days ago
    ​Hello, a few thoughts and ideas for troubleshooting and fixing:
    • Be on latest MR 2012 CU16 release, attached summary of bug fixe and new features (search on export and many fixes over past few CUs; also make sure Office and Windows version is latest/greatest
    • Create a new simple report to export to see if happens to all, and new, reports
    • Make sure all instances of Excel are closed before exporting
    • Try from different computer and user; check with IT in case any firewall or other roadblocks
    • There was a past case where this KB helped:
      • https://blogs.technet.microsoft.com/the_microsoft_excel_support_team_blog/2012/11/12/microsoft-excel-or-microsoft-word-does-not-appear-in-dcom-configuration-snap-in
    Happy Thanksgiving GPUGers!
    Derek Krebs
    Sr Consultant
    MSX Group
    derek.krebs@msxgroup.com
