Smart Connect Payable upload is really slow
  • 1.  Smart Connect Payable upload is really slow
     Hi All:
    We just implemented smart connect with GP 2013. Our consultant created maps for GL and AP. GL map works fine but Payable map  is really slow –The timing is very  inconsistent. 1500 lines file is taking three hours or more. Consultant created a staging table and date moves from stating area to processing area. We wanted to go on auto schedule but with these long hours to upload a file we are unable to go for auto schedule. Our understanding is smart connect is very powerful tool and uploads transactions faster but our experience is otherwise. What could be the reason(s) for these longer processing times?
    Gayathri
    Gayathri Amancherla
    Asst.Controller
    HumanGood.org
    Pleasanton CA
  • 2.  RE: Smart Connect Payable upload is really slow
    Gayathri,
    That is unusual.  I doubt very much that it is a SmartConnect issue.  I would look for things like resource contention or possibly something like an anti-virus software interfering.
    I would start with stripping your integration down and then building it up one piece at a time until you identify the slowdown.  For example, get your source data into a flat text file and write a map that just creates the transactions (payables) in GP.  Take timings.  Then, have it read your data from your real source (staging table).  Take timings.  Then, add any writebacks or file handling tasks.  Take timings.  Then, add scheduling.  Etc.
    Do these steps in your production environment.
    Good luck.
    Healthmark Industries
  • 3.  RE: Smart Connect Payable upload is really slow
    There are a lot of different things that could come into play and Chris gave some great suggestions on splitting it out to try to narrow it down.
    Here are a couple of things that come to mind on our end:
    - Why is a staging table being used?  I am guessing there is a reason, but it is something to investigate.
    - What version of SmartConnect are you using.  I see it is GP 2013, but hopefully a newer version of SC.
    - Is there a lot of Global Variables setup in your SC system?
    - Is everything being logged?  Maybe the log table needs to be cleared.
    Hope Chris' suggestions and those above help, but if you need, you can certainly contact the SmartConnect support team at 888-319-3663 or support@eonesolutions.com.
    Nicole Albertson
    Product Manager
    eOne Solutions
