Qty Total in Picking Ticket
  • 1.  Qty Total in Picking Ticket
    Posted 21 days ago
    How Adding a QTY Total field in the SOP Picking Ticket Form?
    Angel Cintron
    BI Developer
    PAN AMERICAN GRAIN
    bellevue
  • 2.  RE: Qty Total in Picking Ticket
    It's not uncommon to want a control total at the end of the report, especially if all products are of the same unit of measure, i.e., Each, Case, etc. What you need to do is modify the report with Report Writer (print the Standard report to screen then click on Modify) and add the Quantity field from the sopIndividualPickTicketTemp table and drag it to the SOP Number section (F1) on the report. Double-click on it to access the Report Field Options window and change the Display Type to Sum.
    Exit Report Writer, grant security access to the modified report and print again to confirm you have the results you want.
    Director of Technology
    Mekorma
    ROSWELL GA
