Smartlist
  • 1.  Smartlist
    Posted Aug 06, 2019 05:25 PM
    How can I add PO information to my current SmartList? The current Smart List report I'm running does not have an option to add purchase order number.
    Thanks for your help!
    Debra
    Manager-Accounts Payable
  • 2.  RE: Smartlist
    Posted Aug 06, 2019 08:31 PM
    Hi Debra.
    Can you share what current SmartList you're using?  Either share a screenshot or a good path to which one so I can help you out.
    Kristen Hosman
    Independent Dynamics ERP Consultant
    Mount Evans Consulting LLC
  • 3.  RE: Smartlist
    Posted Aug 07, 2019 07:22 AM
    Good morning,
    Below are some screenshots of the SmartList I'm using.  It appears on the Purchasing Invoice table the PO is under "Description"  however I don't see in the drop down menu to add.
    Debra
    The HoneyBaked Ham Company
  • 4.  RE: Smartlist
    Posted Aug 07, 2019 07:04 AM
    Good morning Debra,
    When you are in the "Columns" window, make sure you are showing "All Columns" --
    Diane Hays, CPA, MBA
    Senior Consultant
    Alta Vista Technology LLC
    Chippewa Falls WI
  • 5.  RE: Smartlist
    Posted Aug 08, 2019 07:13 AM
    Good morning Debra,
    Out of the box Smartlist should give you this information: Purchasing>Purchase Line Items
    This list gives you the following: PO Number, PO Line Status, PO Type, Item Number, Item Description, Vendor ID, Location Code, QTY Ordered, Unit Cost, Extended Cost, Document Status.
    You can sort by date, add columns, etc.
    Denise McCaughan
    Bradenton FL
  • 6.  RE: Smartlist
    Posted Aug 08, 2019 05:20 PM
    Edited by Ryan Galang Aug 08, 2019 05:20 PM
    Hi Debra,
    I noticed that the heading in one of your screenshots is "Search Payables Transactions"...
    The above indicates that you were trying to use the Payables Transactions Smartlist... for Purchase Order specific information, you would want to use...
    • Purchase Orders
    • Purchase Line Items
    • Receivings Transactions
    • Receivings Line Items (just like what @Denise McCaughan mentioned)
    On a side note, which window did you enter the PO information anyway? Is is the Purchase Order Entry or the Payables Transaction Entry window (i.e. "P.O. Number" field on the right side of the window)?
