How to change the default sort order for Item History
  • 1.  How to change the default sort order for Item History
    Posted Aug 20, 2021 10:42 AM
    Edited by Ankit Jana Aug 20, 2021 10:43 AM
    Hi Everyone,
    Newbie here. I was wondering if it's possible to change the default sorting order in the Item History window (Inventory->History).
    When I enter an item, it displays the results in the following order by default:
    Is it possible to reverse the default order?
    Ankit
    Ankit Jana
    Montreal
  • 2.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    Hi Ankit,
    There is no way you can change the layout of the grid in the bottom of this window if that's what you meant by 'sorting' the output..
    But you could create your own smartlist or Excel report based on the content that's coming from the underlying tables or use the built-in view which is going to return the same result: [InventorySalesSummaryPeriod_History]
    I'm fairly confident there is already an existing Excel or SSRS reports that would be part of the out-of-the-box GP reports.
  • 3.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    @Ankit Jana
    There is no option via the standard application.
    However I could make this customization in a few minutes using GP Power Tools - Developer Tools module.
    it would just need a few triggers to make it happen.
  • 4.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    Edited by Ankit Jana 30 days ago
    Thank you so much for your responses @Beat Bucher @David Musgrave
    @David Musgrave, we already have GP Power Tools, can you please let me know how to add those triggers or where can I find the instructions to make the change.​
    Ankit Jana
    Montreal
  • 5.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    Hi @Ankit Jana
    You don't have a valid company name listed so I cannot check your registration for you.
    Please check the Registration window and confirm that the Developer Tools module is registered.
    This module is required to be able to run any custom scripts and triggers.
    David​
  • 6.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    Hi @David Musgrave
    It's registered under ​Conglom Inc. I went through your blog
    and I was able to set up a trigger to change the default selection to 'Hist. & Proj. Annual' from 'All'.
    But I was not able to find the field responsible for sorting the results by date in descending order in the Item History Window to set up the trigger.
    Ankit Jana
    Montreal
  • 7.  RE: How to change the default sort order for Item History
    Posted 30 days ago
    @Ankit Jana
    The coding required is more complex as it requires concepts such as auto disabling triggers to capture and store table references, creating of temporary Dexterity indexes (in Descending order) and forcing the window to redisplay using the new index id.
    This is something that most people would say is not possible, but that is just an extra challenge to be met.
    I will have a look at what is needed.
    David​
  • 8.  RE: How to change the default sort order for Item History
    Posted 29 days ago
    David, I would be interested in seeing what you come up with as well since we have a few windows that we would like to be able to sort differently.
    Thanks for being such a responsive member on these pages.
    Greg Wahl
    IT Applications Supervisor
    Owensboro Municipal Utilities
    Owensboro KY
  • 9.  RE: How to change the default sort order for Item History
    Posted 28 days ago
    Hi All
    You will be pleased to know that the concept works.
    I have been able to reverse the order of the data display on the Item History window.
    I need to do a little more work to make sure all the options work and then I will post the example on the blog.
    To make sure you see the article, subscribe to http://WinthropDC.com/Blog.
  • 10.  RE: How to change the default sort order for Item History
    Posted 28 days ago
    Great, Thanks Dave.  I will be sure to keep an eye out for that blog.
    Greg Wahl
    270-926-3200 x4109
    CONFIDENTIALITY NOTICE: This email message and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient or a person responsible for delivering this message to an intended recipient, please contact the sender by reply email and destroy all copies of the original message.
  • 11.  RE: How to change the default sort order for Item History
    Posted 28 days ago
    Edited by Ankit Jana 28 days ago
    @David Musgrave
    Great news!!
    I will be looking forward to that article :)
    Ankit Jana
    Montreal
  • 12.  RE: How to change the default sort order for Item History
    Posted 24 days ago
    Article published today
    https://winthropdc.wordpress.com/2021/08/30/gppt-reversing-the-sort-order-of-the-item-history-window/
