  • 1.  Copy and Paste Function not working
    Posted Sep 22, 2021 09:39 PM
    I just got a new computer and now the copy & paste function isn't working. Each time I try to do it, It just pops up to print the GL report. I tried installing Open XML SDK 2.0 but it still hasn't worked.
    Thanks in advance.
    Tricia
    Tricia Crowell
    Atlantic Corporation Limited
    Halifax
  • 2.  RE: Copy and Paste Function not working
    Posted Sep 28, 2021 05:02 PM
    Hi Tricia,
    Which function of the Copy / Paste are you trying to use ? in the G/L JE Entry form ? or another GP form ?
    I don't believe the Open XML SDK 2.0 is a requirement to use that, all you have to do is to make sure the GP client was installed the right way with all the pre-requisites. Make sure your Excel is installed locally...
    If you could also provide some screenshots or the key combination you press when this is happening, it could help.
