Hi
@Corey Clay,
With regard to adding the Project Number, it sounds like you're missing at least one table. The PA Billing Historical Trx show the summary information for that transaction. It is similar to how the SOP module has "Sales Transactions" and "Sales Line Items".
You would want to look at linking the PA Billing Historical Trx table to the
PA Billing Detail HIST. The actual tables are the PA33100 and PA33200 respectively. That would let you pull in both the header and detail information in a single report.
With regard to the speed issues I haven't noticed it specifically with Project Accounting, but a few items to consider are below:
1.) Is it just the project accounting smartlists that are slow or are there other performance issue areas (other SmartLists, other areas of GP, etc.)?
2.) Are the performance issues limited to a certain number of users or machines or is it experienced for all user/machine combinations? Is it significantly better if you perform it directly on the server?
3.) Do you have a LOT of project accounting records? If SmartList is trying to churn through 70k plus records, it's going to be slower. At some point you may want to consider if another medium (like SSRS or excel reports) is a better vehicle for these exceedingly large datasets.
Does that all make sense? Let me know if not.
Sent: Feb 16, 2021 10:59 PM
Subject: Project Accounting SmartLists
Hi Everyone - One of my customers is trying to run Project Accounting SmartLists and they are VERY slow to populate. It is populating about one record per second. Has anyone else encountered this and resolved the performance? They are also trying to add the Project Number field to the PA Billing Historical Trx and it doesn't seem to be available. Unfortunately, I do not have much experience in Project Accounting.
Corey Clay
Senior Technical Consultant
NexTec Group
