Changing a GL account number
  • 1.  Changing a GL account number
    Posted 18 days ago
    We originally setup an overhead account with the leading account numbers as 648-XXXX-XXXXX. To better organize our chart of accounts we want to update the overhead account to be 100-XXXX-XXXXX. There has been activity in the account. Is there a simple way to just update the account? What is the best way to do this?
    Thank you,
    Cassey Pearson
  • 2.  RE: Changing a GL account number
    Posted 18 days ago
    I believe you could use Account Modifier/Combiner to do this. Account Modifier/Combiner is part of the Professional Services Tools Library (PSTL).
    You would need to install the PSTL if it isn't already.
  • 3.  RE: Changing a GL account number
    Posted 18 days ago
    Edited by Cassey Pearson 18 days ago
    Thank you! I just learned we do not have the PSTL installed yet.
    Cassey Pearson
  • 4.  RE: Changing a GL account number
    Posted 18 days ago
    Do you have any 3rd party products? You may want to double check and see if any of those product could be affected after changing your GL account. The PSTL tool is very useful but doesn't update all areas in GP if you have third party products. Best to run this in a test company first and test everything before running it in production.
    Christine Boisvert
    Vivid Reports
    Winnipeg MB
  • 5.  RE: Changing a GL account number
    Posted 18 days ago
    Hi Cassey,
    I recommend you do it first in your TEST environment.   Hope the attached document guide helps.
    Cecile Dinh
