Error at the Calculate Check step during Payroll run
  • 1.  Error at the Calculate Check step during Payroll run
    Posted Dec 30, 2019 05:58 PM
    After applying the year end update to my Dynamics GP 2015 R2 Test system I am encountering the error below at the Calculate Checks step during a pay run.
    The complete error message is …
    Unhandled Script exception:
    SCRIPTS – data area
    EXCEPTION_CLASS_SCRIPT_ADDRESSING
    SCRIPT_CMD_LOAD
    Any thoughts on where to start to trouble shoot this one?
    Brian Heiple
    Sr Application Analyst
    Lutheran Social Service of Minnesota
    Saint Paul MN
  • 2.  RE: Error at the Calculate Check step during Payroll run
    Posted Dec 31, 2019 09:27 AM
    You might try the following solution posted by Terry Heley:
    https://community.dynamics.com/gp/b/dynamicsgp/posts/you-may-receive-the-following-error-when-you-run-payroll-unhandled-script-exception-scripts-data-area-exception-class-script-out-of-range-script-cmd-lindex
  • 3.  RE: Error at the Calculate Check step during Payroll run
    Posted Dec 31, 2019 09:48 AM
    Mark,
    I did see Terry's post and I don't find the results she notes in the post also the message I getting is slightly different.
    Brian Heiple
    Saint Paul MN
  • 4.  RE: Error at the Calculate Check step during Payroll run
    Posted Dec 31, 2019 09:32 AM
    Hi @Brian Heiple
    Can you scroll down and see if there is more to this message?  There usually is.  That is where we'd find more info in order to help.​
  • 5.  RE: Error at the Calculate Check step during Payroll run
    Posted Dec 31, 2019 09:55 AM
    Hi Jo,
    The complete message is below.
    SCRIPTS – data area
    SCRIPT_CMD_LOAD
    Brian Heiple
    Saint Paul MN
  • 6.  RE: Error at the Calculate Check step during Payroll run
    Posted Dec 31, 2019 09:42 AM
    Brian
    I am not sure that I have run across that error but I have had many people say they can't calculate checks for 2020 after building the year-end wage file for 2019.  When they set the system date to 2020 the checks calculate fine.  Worth a shot I guess but not sure it is the same issue.
    Dawn
    Dawn Schwarz
    Senior Consultant
    Wipfli
    Madison WI
  • 7.  RE: Error at the Calculate Check step during Payroll run
    Posted Jan 28, 2020 11:54 AM
    Hi Brian,
    Did you ever come up with a solution to this? We just started getting this error when calculating checks (after installing the 2019 YE update), but it doesn't seem to happen with every check run for some reason. Trying to figure out what it might be in the batches that won't calculate that's causing it. Thanks!
    Nick Rodriguez
    ATC Healthcare Services
