Item Cost Change History
Jump to Best Answer
  • 1.  Item Cost Change History
    Posted Sep 14, 2021 03:26 PM
    Our Item Cost Change History/IV00118 is empty. Can someone please shed some light on how to get this table populated?
    I did some research on it but I did not find much.
    Thanks in advance!
    Aref Karam
    Data Consultant
    LTI Information Technology
    Ann Arbor MI
  • 2.  RE: Item Cost Change History
    Best Answer
    Posted 30 days ago
    Aref,
    Are you using standard costing with Manufacturing?  If so, check the CT00200 table.  This table holds the Manufacturing Standard Cost changes.  though it would also make an entry into the IV00118 table when standard cost rollup and revalue is completed.
    Andrew Kennedy
    Principal Consultant
    Velosio
    Seven Hills OH
  • 3.  RE: Item Cost Change History
    Posted 29 days ago
    Thank you Andrew!
    We don't use the GP Manufacturing module. We use HMS so I guess we cannot use that table for cost changes.
    Aref Karam
    Data Consultant
    Ann Arbor MI
  • 4.  RE: Item Cost Change History
    Posted 29 days ago
    Hi Aref,
    Yes I believe Horizon has it's own standard cost tables.  I'm not sure if it maintains it's own standard cost history.
    Andrew Kennedy
    Velosio
    Seven Hills OH
