@Beat Bucher and
@Jo deRuiter,
All right, all right, already! I'll blog about it! I just have to string the clauses together for each step in the workflow.
I know I can do it because I made a refex (that's REE-fex, Jo!) using that technique a few years ago based on the chart of accounts at my former employer. It has tabs for:
Accounts -- just a raw list of all account numbers
Accts by Dept -- a list of the Department numbers (our segment 2) with the base account numbers (segment 1) clumped together in one cell, strung together and separated by spaces
Accts by Category -- a list of the account Categories with the account numbers separated by spaces in one cell per category
Departments by Acct -- and a list of the base account numbers with the departments for each strung together and separated by spaces in one cell per account.
I created a function to return space-delimited strings for each of the "by" tabs. The functions use the FOR XML PATH dodge to string multiple values together. E.g.,
ALTER FUNCTION [dbo].[udfConcatenateAcctNumbersForOneCategory]
@cat varchar(100)
, @postingType smallint
, @typicalBalance smallint
RETURNS varchar(MAX)
AS
BEGIN
DECLARE @Accts varchar(MAX)
SET @Accts = '';
SELECT @Accts = (
SELECT DISTINCT TOP (100) PERCENT RTRIM(g0.ACTNUMBR_1) AS 'data()'
FROM dbo.GL00100 AS g0
INNER JOIN dbo.GL00102 AS g2
ON g0.ACCATNUM = g2.ACCATNUM
WHERE g2.ACCATDSC = @cat
AND g0.PSTNGTYP = @postingType
AND g0.TPCLBLNC = @typicalBalance
AND g0.ACTIVE = 1
FOR XML PATH('')
SELECT @Accts = RTRIM(@Accts);
RETURN @Accts;
END
So I just have to adapt that method for the Workflow and that should do it.
Blog:
https://www.gpug.com/blogs/steve-erbachTwitter: twitter.com/serbach
Excel Webinar List as of 12-Nov-2019------------------------------
Sent: Apr 27, 2020 12:42 PM
Subject: OK, I give up: How do you document your WorkFlow?
@Steve Erbach
This is good stuff that you brewed in your (hell) kitchen !! certainly worth a blog entry once tackled as suggested by @Jo deRuiter
Sent: Apr 24, 2020 04:05 PM
Thaddeus,
Interesting to see the difference in scope between your company and ours. We only have 45 employees!
Working on this Workflow documenter I can see why Microsoft elected not to produce one of their own. The Workflow tables are pretty generic; so specific documentation of a Workflow would be problematic.
Sent: Apr 24, 2020 02:26 PM
If you ever need to know what the status code mean...here they are:
Workflow_status
Sent: Apr 24, 2020 08:37 AM
Why, hello, @Jo deRuiter! Thank you for chiming in!
I've been playing with the WF tables and I've almost got it. I've figured out the "QueryCondition" enumeration -- at least, for the query terms we use in our Workflow.
Here's what I've got so far:
SELECT s.Workflow_Name
, s.Workflow_Step_Name
, s.Workflow_Step_Sequence
, s.WF_Step_Description
, s.Workflow_Step_Order
, s.WF_Step_Predecessor
, u.ADDisplayName
, c.ConditionsGuid
, c.SEQNUMBR
, c.FromTable
, c.FromField
, c.QueryOperator
, c.QueryConditon
, c.StringFilter_1
, c.NumericFilter_1
, CASE
WHEN RTRIM(c.StringFilter_1) > '' THEN
CASE c.QueryOperator
WHEN 1 THEN 'Where ' + RTRIM(c.FromField) + ' = "' + RTRIM(c.StringFilter_1) + '"'
ELSE ' Or ' + RTRIM(c.FromField) + ' = "' + RTRIM(c.StringFilter_1) + '"'
END
ELSE
CASE c.QueryConditon
WHEN 7 THEN ' And ' + RTRIM(c.FromField) + ' >= ' + FORMAT(c.NumericFilter_1, 'N', 'en-us')
ELSE ' And ' + RTRIM(c.FromField) + ' <= ' + FORMAT(c.NumericFilter_1, 'N', 'en-us')
END
END AS Clause
FROM dbo.WF100003 AS s
INNER JOIN dbo.WF40200 AS u
ON s.Workflow_Step_Assign_To = u.UsersListGuid
INNER JOIN dbo.CO00123 AS c
ON s.Workflow_Step_Conditions = c.ConditionsGuid
WHERE s.Workflow_Name = 'GLC PO Workflow'
ORDER BY Workflow_Step_Order
, WF_Step_Predecessor
, Workflow_Step_Sequence
, SEQNUMBR;
Sent: Apr 24, 2020 07:51 AM
Look in this table: CO00123
The Key in 'ConditionGuid' will link back to the WF100003 table on the 'Wordkflow_Step_Conditions" field.
The CO00123 holds the actual steps, though most of them are integer-represented and I can't find any documentation on the integers.
Sent: Apr 23, 2020 08:07 AM
Dear Collaborators,
I cannot seem to locate a WorkFlow documenter report. That is, I want to see a report that shows all the Steps and sub-Steps along with the conditions for each one. Am I missing an SSRS report that has this?
Something like this:
Productionwhere Purchase Order Work.Buyer ID is 'Bob'
and Purchase Order Work.Subtotal is greater than and includes 5000.00
and Purchase Order Work.Subtotal is less than and includes 9999.99
or Purchase Order Work.Buyer ID is 'Frank'
Prod over 10000where Purchase Order Work.Buyer ID is 'Bob'
and Purchase Order Work.Subtotal is greater than and includes 10000.00
and Purchase Order Work.Subtotal is less than and includes 24999.99
etc.
Am I missing something obvious? Is there such a report? I've been putting one together with SQL, but hey! How about a little relief here?
