Report Writer help with Calculated Field
  • 1.  Report Writer help with Calculated Field
    Posted Feb 12, 2020 11:22 AM
    Need a simple calculate field but don't know how to express "null" or "blank" in RW...
    Need:
    IF "Sales User-Defined Work History user defined table 1" not Null
    Then "Sales User-Defined Work History user defined Table 1"
    Else "Constant"
    I have the user defined table 1... no prob.
    I have the constant I want if the field is blank or null...
    I see "not" clearly... but how do I get the tool to accept "null" or "Blank"?
    Justin Ross
    Sarasota FL
  • 2.  RE: Report Writer help with Calculated Field
    Posted Feb 12, 2020 11:46 AM
    Hi Justin,
    You should be able to do this by selecting the Constants tab, select the String type, leave the Constant field blank and click Add.  This will enter an empty string.
    Jamie Evenson
    CEO
    Najaxa Software
    Las Vegas, NV
  • 3.  RE: Report Writer help with Calculated Field
    Posted Feb 12, 2020 10:59 PM
    Thank you!  Once I figured out the " <>"  is way better than "NOT =" it worked great!
    Now I get to post another Help!! on the template itself!   Grrr...
    Thanks again!
    Justin
    Justin Ross
    Sarasota FL
  • 4.  RE: Report Writer help with Calculated Field
    Posted Feb 13, 2020 01:37 AM
    @Justin Ross
    Glad you got this sorted.
    Just a note. Dexterity (the language behind GP) does not understand the concept of Null. It knows blank or empty records such as zero numerical values or ​empty strings.
    Where this can have an effect is if performing outer joins at the SQL level (as a developer or for a Smartlist query) you must use isnull() or coalesce () to ensure that possible null values are replaced with empty or blank values.
    Just a bit of geek knowledge for you.
    Enjoy
