Employee Deduction Code needs to be marked TSA Sheltered
  • 1.  Employee Deduction Code needs to be marked TSA Sheltered
    Posted Feb 21, 2020 10:37 AM
    I have a deduction code which is set up to be tax sheltered.  When the code was added to an employee, the using default was not selected.  So, the deduction for that one employee is not marked tax sheltered.  I can not change it in Employee Deduction Maintenance because it has one transaction.  Is there a way to correct this?
    Gina Briley
    Finance Administrator
    North Little Rock Waste Water Utility
    North Little Rock AR
  • 2.  RE: Employee Deduction Code needs to be marked TSA Sheltered
    Posted Feb 24, 2020 01:05 AM
    You'd need to use a SQL query to update UPR00500. If the setup code needs to be updated you'd update UPR40900.
    You'll want to view the records for an employee record with the right settings and then update the other employee to have the same settings.
    Charles Allen
    Senior Managing Consultant
    BKD Technologies
    Houston, TX
  • 3.  RE: Employee Deduction Code needs to be marked TSA Sheltered
    Posted Feb 25, 2020 05:26 PM
    Has the code been used for that employee?  If so, it is recommended to inactivate and create a new code.  The tax reports look at the tax setting at the time of running the report I believe.
    Stefanie Christiana
    Glidewell Laboratories
    Irvine CA
