1099-NEC --> 3-Up instead of 2-Up
  • 1.  1099-NEC --> 3-Up instead of 2-Up
    Posted 24 days ago
    It appears the Federal Government has changed the 1099-NEC form from 2-Up to a 3-up this year.  Our GP still prints the 1099-NEC in 2-Up format.  I have not seen an update to correct this.  Has anyone found a work around for this?
    Brian Barnholtz
    Director of Information Technology
    Fullerton Companies
    Plymouth MN
  • 2.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    The new report format is in the 2021 YE update.  Why could they not just make the new format available on its own? I don't know but we have to try to find time to rush in an update in time for the 1099s.
    Hope this helps.
    Richard Kinning
    Hillsborough Transit Authority (HART)
    Tampa FL
  • 3.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Hi Brian
    Yes, you are correct, this is included in the year end update.
    Here is our year end landing blog page for all modules, check out the FORMS blog
    https://community.dynamics.com/gp/b/dynamicsgp/posts/microsoft-dynamics-gp---2021-year-end-blog-series-schedule
    Here is the US Release blog and download pages
    https://community.dynamics.com/gp/b/dynamicsgp/posts/microsoft-dynamics-gp-u-s-year-end-update-2021-released
    Terry Heley
    Microsoft
    Terry Heley
    HR/PR expert
    Microsoft
    West Fargo ND
  • 4.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Hell Brian
    We found that out at the last minute as well. We have decided to use 1099Pro to print the 1099 NEC and 1099 Misc.
    The excel format that 1099Pro needs is fairly straight forward. The S/W costs little to purchase.
    Let me know if you would like a copy of the SQL views to use.
    RE: YE update, yes that is a huge undertaking as we have to test all the ISVs and custom functionality pieces before rolling out to a live system.
    Best of luck!
    Ven
    Ven Sharma
    Charles Town WV
  • 5.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Ven
    Yes, I would love to have the SQLScripts  I don't want to have to do all of the yearend changes with the special customizations that we have
    Let me know if you can provide
    Linda Krawiecki
    Linda Krawiecki
    P&L Consulting Inc
    Albuquerque NM
  • 6.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Hi Linda
    Here it is. I have also included the 1099Pro format for 2021.
    The sql view attached is for INTERID = TWO01,
    please replace this with your company DB name.
    Best of luck.
    Ven
    DISCLAIMER:
    I don't work for the 1099Pro company.
    Ven Sharma
    Charles Town WV
  • 7.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Thank you I will try running them on my system
    Linda
    Linda Krawiecki
    P&L Consulting Inc
    Albuquerque NM
  • 8.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Thank you for all the information.
    Much Appreciated!
    Brian Barnholtz
    Fullerton Companies
    Plymouth MN
  • 9.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Linda and Brian:
    Here is how to go about using the view.
    1. Point the SQL view attached to your Company DB (found in the first line of the sql script).
    2. Run the query.
    3. Output the results to excel.
    4. Feed the above excel to 1099Pro software.
    Please note the output will have a redundant column called year, that can be used to filter out data.
    It will not hurt the 1099Pro processing if you leave that column in there.
    Best of luck
    Ven
    P:S- I have one for 1099 Misc as well, will attach the same soon.
    Ven Sharma
    Charles Town WV
  • 10.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Ven
    Thanks for the information
    I did put it in my database, but I then created a smartlist in GP to easily sort etc and then send to excel
    Linda Krawiecki
    President
    P&L Consulting Inc
    Office 520-485-1012 Cell 505-250-9256
  • 11.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 23 days ago
    Thanks Ven.  Worked like a charm.  I created the view, and exported to excel.  I was able to import this into the 1099Pro demo software.
    Thank You Again for all your help!
    Brian Barnholtz
    Fullerton Companies
    Plymouth MN
  • 12.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 17 days ago
    Would it be possible for the SQL view?
    Thank you,
    Jennifer Senko
    jsenko@svcw.org
    SVCW
    1400 Radio Road
    Redwood City, CA 94065
    Jennifer Senko
    Silicon Valley Clean Water
    Redwood City CA
  • 13.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 16 days ago
    Hi Jennifer
    The NEC SQL view is attached to this thread.
    Here is the sql view for MISC.
    Ven Sharma
    Charles Town WV
  • 14.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Posted 16 days ago
    Thank you very much for your reply!
    Jennifer Senko
    Redwood City CA
  • 15.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Hi,
    Tried to print 1099 NEC and have installed the 2021 YE Update, but still printing 2 forms to a page.  Is there something else that needs to be done or checked?
    thanks
    Denise
    Denise Amundson
    Senior Accountant
    Sioux Falls SD
  • 16.  RE: 1099-NEC --> 3-Up instead of 2-Up
    You might want to double check that you are not running the modified form from last year
    Linda
    Linda Krawiecki
    P&L Consulting Inc
    Albuquerque NM
  • 17.  RE: 1099-NEC --> 3-Up instead of 2-Up
    We are having the same issue with 1099-nec they are 2 up not 3 up.  Has anyone contacted tech support from sovos (1099pro)?
    Richard Kinning
    Tampa FL
  • 18.  RE: 1099-NEC --> 3-Up instead of 2-Up
    Double check that you have not got the form as a modified form from last year   Last years form was 2  per page
    Linda Krawiecki
    President
    P&L Consulting Inc
