EFT file not generating
  • 1.  EFT file not generating
    Posted Feb 09, 2019 04:14 PM
    We are currently adding vendors to pay via EFT.  We had a power outage recently and since then we cannot generate the EFT files.  I have gone through and check the path of the EFT files and I have processed the "check links" and "reconciliation" for all modules.  Unfortunately, I am getting the same error. I would appreciate any input you may have.
    Thank you
    Dawn Sutton
    Accountant
    Stahmanns Inc.
    La Mesa NM
  • 2.  RE: EFT file not generating
    Posted Feb 11, 2019 08:29 AM
    Looking at the error message it seems to indicate that you are missing the EFT file format setup for that checkbook.  When you go to the EFT File Format do you see a file format for the checkbook?  It would be this window.
    eft format
    Jennifer Wheeler
    Applications Solutions Administrator
    Dairy Farmers of America
    East Syracuse NY
  • 3.  RE: EFT file not generating
    Posted Feb 11, 2019 08:42 AM
    Hi @Dawn Sutton
    Here is my blog on setting up and using EFT - please make sure you have not missed any of the steps:
    Jo's Did You Know "You Can Set Up and Use EFT in Dynamics GP" You Can Send Funds AND Receive Them! A Game-Changer! Part 1 - Microsoft Dynamics GP Community
    Dynamics remove preview
    In this post we'll cover how to Set Up EFT's for Payables and Receivables, in the next post, found HERE we'll take a look at how to use them and the best practices around that! You can set up and use Electronic Payments in Dynamics GP by setting up and using the EFT functionality that's already part of your GP install!
    View this on Dynamics >
    Jo deRuiter , MCP, DCP
    GPUG Academy Instructor
  • 4.  RE: EFT file not generating
    Posted Feb 11, 2019 09:26 AM
    Hi Dawn,
    Simply go to your chequebook (checkbook!) > EFT Bank > Payables Options and check to see if the File Format is listed there. Perhaps with the power outage, something was messed up in setup (although that would indicate you might have other issues too).
    The error indicates the checkbook doesn't have a format selected for it to use.
    @Jennifer Wheeler is correct, if the format is missing entirely, you may need to recreate it. At that point, my recommendation would be to restore a backup of your company from prior to the power outage to a test company database so that you can export the format and import to the company to easily recreate it and know it's exact.
    Thx
    Jen​
    Manager, Business Solutions
    Energy+ Inc.
    Cambridge, ON, Canada
  • 5.  RE: EFT file not generating
    Posted Feb 11, 2019 09:28 AM
    Good morning,
    I have verified the information.  What I don't understand is that the EFT has been working for over a month now.  I have just been adding new vendors along the way.  One of my vendors on this EFT submission is one I have been sending payments via EFT since I first set it up.  We have not had any problems until this last week.  The only thing that happened was a power outage and since then I cannot get it to work.
    Dawn Sutton
    Accountant
    Stahmanns Inc.
    La Mesa NM
  • 6.  RE: EFT file not generating
    Posted Feb 11, 2019 09:33 AM
    I'll admit it doesn't make sense, hence my comment that it could be indicative of other issues potentially. It would be unusual for one thing to somehow break due to an unplanned cut of power and nothing else to be affected.
    The reality is it's either a user-based change to setup that occurred or a result of the power outage that may have changed something.
    Energy+ Inc.
  • 7.  RE: EFT file not generating
    Posted Feb 12, 2019 09:59 AM
    @Dawn Sutton since you have verified your settings and you mentioned a power outage I would recommend a server reboot. Like most programs GP can be quite sensitive ​​when there is a power interruption. Sometimes rebooting will help reset things.
    We have noticed performance issues even when there are Microsoft updates waiting to be installed on the servers. So, we just plan a reboot in the evenings to install them. With that practice we haven't had any major issues in a while (knock on wood). 8-)
    Joni Finnell
    GP Projects/Troubleshooter
    Newark OH
  • 8.  RE: EFT file not generating
    Posted Feb 12, 2019 11:35 AM
    I appreciate everyone's input.  I believe we finally got everything fixed.  Have a good day.
    Dawn Sutton
    Accountant
    Stahmanns Inc.
    La Mesa NM
