OK. Did you check David's suggestion of permissions on the custom dex.dic. Make sure under security it is full control, modify, read and execute, read, write allow for Users in addition to Administrators/system.
I checked dex.ini settings for showallmenuitems = false and that does not effect Form Additional Menus only the Navigation Menus and dropdown Menus
Also in a Citrix farm you are best to disable roaming profiles but I don't think that is your issue if you are not using user specific dex.ini files.
However typically in Citrix we do not share the dex.ini file
Sent: Jan 07, 2021 03:32 PM
Subject: Additional Menu - Items missing
Local Citrix connector Citrix Workspace 2010 20.10.0.20
Citrix Verson: 1909
Win Server 2016 VDA server 16gb Ram 6 CPUs 1.70GHz
GP 18.00.0704
No enableperuserini = true line in the DEx.ini
Only 25 rows in the Dynamics..SY01405 table for 3 GP users. None of the 3 match the user seeing this menu issue.
David Morinello
Ascend Learning, LLC
Leawood KS
Sent: Jan 07, 2021 02:57 PM
What version of XenApp? And are you using roaming profiles? And enableperuserini = true? (SY01405 Form and Report Paths are stored by user)
Sent: Jan 07, 2021 12:46 PM
Ok this is the oddest test result yet.
- I created a new GP user account from scratch for Nalin. No account copying from GP, Straight new user account.
- I created the new GP account checkbox by checkbox with the same Roles, Tasks, and AMFR as his original. No Homepage Role to start off.
- He logged into Citrix and starts up GP Nalin.Jain2 GP account and does not see the two menu items.
- He logs off and I sign into the same GP Account from My Citrix and yes I see the two menu items.
- I log out of GP and he logs into the same QA GP Citrix link again, same Nalin.Jain2 GP account and still does not see the two menu items.
This seems to eliminate any GP direct issues with Security, AMFR, Dictionary corruptions, etc. Same GP Client, Dynamics.set & Dex.ini
Any Citrix, Windows, or Folder level settings that might prevent the Additional Menu items from displaying for one user but not an admin user?
David Morinello
Leawood KS
Sent: Jan 07, 2021 02:11 AM
Items on the Additional menu are added by Dexterity Form triggers and are not usually affected by Security settings.
I wonder if there is some sort of corruption/permissions issue with the dictionaries.
Sent: Jan 06, 2021 04:51 PM
Does anyone know what might cause some items under Sales and the Additional menu to be missing?
I have two users who are missing two Dexterity Customizations under the under Sales > Additional menu
- Both users are using the same GP Client and launch file, as do others that work ok
- One of the two, Cristina, just stated working a few weeks later, the other is still missing the rows shown below
- If I create a test user and copy the access, the test user sees the menu items. So, same GP Security
- Some Users testing are SuperUser/Admins. Two failed, and one of those started working. Others with the same Roles & Tasks always worked ok.
- Check links in Security don't find anything.
Under the Sales Transaction Entry Screen > Additional menu > Two rows the match to an internal Dexterity Customization.
Ideas, suggestions?
David Morinello
Leawood KS
