Unposted APAY General Ledger Batches due to Currency Issues
  • 1.  Unposted APAY General Ledger Batches due to Currency Issues
    Posted Jul 09, 2019 08:35 AM
    Problem: APAY Sub-Ledger batches that will not post to the GP General ledger
    Cause: The Transaction Currency on the individual Payables transactions = CND (Canadian Dollars) and the GL Distribution Accounts on the transactions only allow US dollar transactions.  Note:  These transactions were integrated into GP via a PO Receipt SmartConnect integration with the wrong CurrencyID's.
    What would be the best way to correct this? Is there a table that I can simply update/change the currency ID?
    Thank you
    Renee Boucher
    Data System Services
    Sterling Heights MI
  • 2.  RE: Unposted APAY General Ledger Batches due to Currency Issues
    Posted Jul 09, 2019 06:28 PM
    So the batches are in the GL already?
    Or are you still posting on the AP module?
    If already in the GL side, you can check the GL10001 table.. the currency info should be in there.
    I would recommend backing up the table before doing the update.. you will want to check also the exchange rate info as it will be stored in there.
    If in the AP module, it will be in the PM10000 table, but you will need to check the distribution table as well: PM10100..
    *based on the voucher number.
    ***but if you can re-do the upload, it may be easier to just delete the batch in the GP, modify the currency on the upload file, and re-upload.. that will be safer.
    Elena Papio
    Glidewell Laboratories
    Irvine CA
  • 3.  RE: Unposted APAY General Ledger Batches due to Currency Issues
    Posted Jul 10, 2019 09:48 AM
    I am able to locate the batches in the GL10001 table however I'm not seeing where the Currency can be altered. I've attached an example.
    Thank you
    Renee Boucher
    Sterling Heights MI
    txt
    GL10001.txt   4K 1 version
