Inventory Reason Codes
  • 1.  Inventory Reason Codes
    Posted Jul 27, 2020 10:50 AM
    We are deciding if we should use the inventory reason codes for our inventory adjustments / transfers.
    I would like to be able to use Smartlist to pull by a date range and by reason code.  I cannot seem to find the reason code used in the inventory adjustment / transfer - only the set up reason code table IV40300.  What am I missing?
    Debbie Janssen
    Accounting (AR and AP) and GP Maint
    Sure Controls Inc.
    Greenville WI
  • 2.  RE: Inventory Reason Codes
    Posted Jul 27, 2020 11:45 AM
    Hi @Debbie Janssen,
    What tables are you looking at or what default SmartLists are you using?
    The field itself is contained in the IV10001 (work ​transaction line detail) and the IV30300 (transaction amount history line detail).  It is called Reason_Code in each.
    Based on a quick review of the InventoryTransactions view (which is used in the default inventory transactions smartlist), I do not see reason code included.  You may need to create a SmartList that combines the necessary tables (IV10001, IV30300, etc.) based on what you need in order to be able to reference the Reason Code.
  • 3.  RE: Inventory Reason Codes
    Posted Jul 27, 2020 11:50 AM
    Thank you!  I looked and did not find table IV10001.
    Thank you again.
    Debbie Janssen
    Sure Controls Inc.
    Greenville WI
