Bank deposits not creating automatically
  • 1.  Bank deposits not creating automatically
    Posted Oct 24, 2019 03:47 PM
    Hi all.  We are on GP2016 and recently setup the feature to automatically create bank deposits from cash receipts.  The feature is not working for us.  After we post the cash receipts, this error pops up.  We hit OK and when we go go bank deposits, we have to create the bank deposit just as we did before.  Any suggestions?
    Bank Deposit error
    Cash receipts setup
    Kathy Kim
    Director of Finance
    Donor Network of Arizona
    Phoenix AZ
  • 2.  RE: Bank deposits not creating automatically
    Posted Oct 24, 2019 04:24 PM
    Hi Kathy,
    Can you please check if Method 2 or 3 of the article below applies to your situation ?
    Cash Receipts automatically deposit into Bank Rec in Microsoft Dynamics GP
    Gerald Buenafe
    Owner/Consultant
  • 3.  RE: Bank deposits not creating automatically
    Posted Oct 24, 2019 04:34 PM
    Thank you Gerald - this fix seems to be related to the cash receipts creating individual bank deposits whereas ours is not creating any bank deposits at all.  I don't believe that we have Multicurrency Management enabled, so I will check to see if that is causing the issue.  Thanks for the suggestion.
    NOTE: In Microsoft Dynamics GP 2016 RTM (16.00.0404), this same company option will now post cash receipts in the same 'batch' as a 'lump sum deposit' in Bank Reconciliation.
    (Note: However, cash receipts may still post as single desposits if 1) Multicurrency Management is not enabled.  You must turn on Multi-currency Managment.  This will not be changed.  Or 2) if you have Project Accounting installed. You would need to set security to the non-PA window for Cash Receipts Entry and Receivables Batch entry windows as the work-around.   This will be considered for a future update.
    Kathy Kim
    Director of Finance
    Phoenix AZ
  • 4.  RE: Bank deposits not creating automatically
    Posted Oct 24, 2019 05:26 PM
    Hi @Kathy Kim
    Do each of you have securities to do the deposits in Financial or to Post Through on those transactions?​
    The other aspect is that, even though you are not using Multi-currency you MUST turn it on for this functionality to work.
  • 5.  RE: Bank deposits not creating automatically
    Posted Oct 24, 2019 05:31 PM
    Thank you for the suggestions.  Everyone does have the security necessary.  I believe that MultiCurrency is likely the culprit.  I doubt that we have this turned on.  I need to check this out when everyone is logged out and then confirm with my partner that turning this on won't cause any issues with anything else that we are doing.
    Kathy Kim
    Director of Finance
    Phoenix AZ
