AP Voucher
  • 1.  AP Voucher
    ​​Hi
    I have a work voucher that I'm editing to change the account number when the power went off.
    So when I log back in to GP to edit the voucher, I got this message
    Error
    The voucher is not posted but I can't seem to open it and edit the account number.
    Do you know how can I correct it?
    In the edit list it shows this message:
    Edit List
    Can somebody help me please?
    Thanks.
    Dama Lagman-Taruc
    College of Nurses of Ontario
    Toronto ON
  • 2.  RE: AP Voucher
    Hi Dama,
    do you know if it saved in a batch?  if so try deleting the batch
    Gerald Buenafe
    Owner/Consultant
  • 3.  RE: AP Voucher
    Hi Gerald,
    Thanks. Yes, it is in a batch and I have a few batches in the batch.
    Is that the only solution​?  Then I have to move all the vouchers in a different batch.
    Will I be able to delete the batch then?
    Dama Lagman-Taruc
    Toronto ON
  • 4.  RE: AP Voucher
    yes. that is most likely. or else we you have to go to the sql tablea and delete it.
  • 5.  RE: AP Voucher
    Hi Dama,
    Reach out to your GP partner, they can likely do some SQL magic and get this voucher back into 'work' status. I've had the same thing happen a few times over the years, and when the connection is disrupted like that, GP can do some funny things and vouchers end up in the ether between posted and unposted. But they usually can be recovered by someone with SQL knowledge.
    Hope that helps!
    Joe Scheidecker
    Accounting Manager
    Guardian Energy
    Hankinson ND
  • 6.  RE: AP Voucher
    Hi Joe,
    Thanks, this will really help going forward. I decided to just delete the batch.
    Reaching out to our TI folks will take some days​, but I will let them know about this problem.
    Dama Lagman-Taruc
    Toronto ON
  • 7.  RE: AP Voucher
    Hi @Dama Lagman-Taruc
    "How" are you trying to open it?  For instance, are you at Transaction Entry and using the lookup?  Are you in SmartList and Trying to double-click or are you using the next buttons on the transaction entry window?​​
  • 8.  RE: AP Voucher
    Hi Jo,
    I am in the transaction entry entering the number and also opening it on the lookup.
    Thanks.​
    Dama Lagman-Taruc
    Toronto ON
  • 9.  RE: AP Voucher
    @Dama Lagman-Taruc
    Do you get the same error when you use the lookup, find it and then double click it?​
