Item Master Description on PO Blank Form
  • 1.  Item Master Description on PO Blank Form
    ​​I'm trying to get the item description from the item master to print on the PO Blank Form when the line item is an inventory item. If it's not, I want the description entered on the PO.
    I'm using a calculated field based on the value of Non IV field. Unfortunately, that field is returning nothing so the calculated field is returning nothing.
    If anybody has an idea, I'd be obliged.
    Thank you
    Charles Allen
    Senior Managing Consultant
    BKD Technologies
    Houston, TX
  • 2.  RE: Item Master Description on PO Blank Form
    Hi @Charles Allen
    You should be able to get this to work with a relationship to the Item Master table.
    However, if you still have trouble, a quick customer user defined RW function created with GP Power Tools can provide this for you very easily. I would be happy to write the code and provide you with the configuration setup file.
    David​
  • 3.  RE: Item Master Description on PO Blank Form
    ​Thank you, David. The problem I'm having is getting the value of Noninven to show and then use as part of an expression. I've added the field to the report but get nothing to print. So, if that field won't print a value then the calculated field won't work, either.
    Charles Allen
    BKD Technologies
    Houston, TX
  • 4.  RE: Item Master Description on PO Blank Form
    Hi @Charles Allen
    My plan was to pass the transaction line key fields to a Custom GP Power Tools RW function which would look at the Tables and return the description from the item or from transaction line as per your requirements.
    I would either be able to check the NonIV flag or look up the item in the Item Master table.
    So I am very sure this method will work fine.
    Let me know if you want more information.
  • 5.  RE: Item Master Description on PO Blank Form
    @Charles Allen and @David Musgrave,
    Kinda sounds like a table relationship thing.​​ I've opened the report definition for the POP Purchase Order Blank Form (that's the one I assume you're using) and this is what I see in the Report Table Relationships:
    Are you trying to hang the Item Master off of the Purchase Order Line Rollup Temp? This is the list of current Relationships for that table:
    Is this where you've created a relationship to the Item Master?
    Then where do you want to place the calculated field? In one of the zillion headers? It would be instructive if you could give details of what you're trying to do... with pictures!
  • 6.  RE: Item Master Description on PO Blank Form
    Thank you for your feedback.
    In my vanilla environment, I've got everything working well. In it, I joined Purchase Order Line TEMP to Purchase Order Line Rollup Temp. Then I joined Item Master to Purchase Order Line TEMP. A calculated field based on the Noninven field is working well.
    Unfortunately, the client is using MEM and the PO is coming from that dictionary. That one doesn't seem to be working the same way.
    Charles
    Charles Allen
    BKD Technologies
    Houston, TX
