Voided RCT Not Visible in POP Returns
  • 1.  Voided RCT Not Visible in POP Returns
    Posted Jan 02, 2019 02:22 PM
    Edited by Alan Strutz Jan 02, 2019 03:29 PM
    We have situation where an invoice for a receiving was voided through AP as a means to clear the invoice from the vendor record, which, obviously, left the quantity received still in inventory. I'm trying to do a return through POP on that receipt in order to correct the inventory. After entering the correct PO and item number, I try to pull up the associated receipt but no document is visible. GP acts as if the receiving was voided, too, despite there being no inventory adjustment made.
    Is the simple solution to just do an inventory adjustment? Or should I be able to do a return on the original receipt?
    Thanks for the help!
    #GP2015and2015R2
    Alan Strutz
    Assistant Controller
    Sugar Mountain
    Seattle WA
  • 2.  RE: Voided RCT Not Visible in POP Returns
    Posted Jan 04, 2019 11:27 AM
    Yes, you do an inventory adjustment now. Make sure the debit goes to RNI as when you voided the AP invoice it should have credited RNI and debited AP.
    Next time you could do a POP Return with Credit Memo type  and then you would have managed the inventory and created an AP credit memo (to apply to the invoice) all in the Return transaction.
    But since you did the AP void, now you need to clean up the inventory. Just make sure you clear the correct account - probably RNI.
  • 3.  RE: Voided RCT Not Visible in POP Returns
    Posted Jan 04, 2019 12:46 PM
    I assumed that that was the only option, so we went through the process you describe, yesterday, and it appears to have worked just fine. Thank you for confirming my suspicions.
    Alan Strutz
    Sugar Mountain
    Seattle WA
