This only means the receipts are fully consumed based on your inventory valuation method - this happens often when receipts are of Shipment/Invoice type. The workarounds, should you want to avoid the headaches, are as follows:
1. Print the Purchase Receipts report (Inventory > Reports > Activity > Purchase Receipts) and see if you can spot other receipts you can pull from.
or,
2. You can do the return manually by posting two separate transactions, the first one is adjustment entry to correct the inventory balance, and the other transaction is an AP credit memo to correct the vendor balance (if needed).
Director of Technology
Mekorma
ROSWELL GA
Sent: Aug 12, 2020 05:38 PM
Subject: Purchase Return
I have a number of open receipts that need to be switched to different PO's. The receipts will not come up as an option to pick in the Purchase Return transaction entry window. I have checked that there is enough inventory available, I have reconciled the items and the receipts still don't some up. The PO is not closed.
Why will the receipt not come up to be returned and backed out?
Is there another way to do this?
THANK YOU!
Teresa Waters
La Crosse Milling Company
Cochrane WI
